Unread 04-28-2019, 11:15 AM   #16
PC7060
PC7060's Avatar
Sure here ya go.....
2012 - International Plumbing Code
CHAPTER 7 SANITARY DRAINAGE
SECTION 709 FIXTURE UNITS
https://codes.iccsafe.org/content/IP...itary-drainage
Unread 04-28-2019, 04:53 PM   #17
fordperson
some follow up on my original question
apparently any vent that is not vertical needs to be washed using another fixture. Im guessing because of potential clogging issues?
time to rip into the wall and make a vertical vent.
https://terrylove.com/forums/index.p...-shower.81370/
Tom
fordperson is offline   Reply With Quote
Unread 04-28-2019, 06:00 PM   #18
PC7060
PC7060's Avatar
How far is the shower drain from the toilet vent? If within 6’ (8?) you don’t need need another vent for shower.
I’ll have to look up the exact distance requirements.
Unread 04-28-2019, 06:06 PM   #19
PC7060
PC7060's Avatar
Here you go....
So with your 2” drain, your shower trap can be a maximum of 8’ from toilet vent.
TABLE 909.1 MAXIMUM DISTANCE OF FIXTURE TRAP FROM VENT
Here is a link to the chapter 9 venting for the 2012 IPC. The 2018 version is the same.
https://codes.iccsafe.org/content/IP...hapter-9-vents
Unread 05-28-2019, 12:07 PM   #20
fordperson
framing corners
Can someone tell me if this is sufficient corner support or should I add more directly in the corner?
Also my drywall (tiling the whole bathroom, not just the shower area) are significantly built up to where the gap in the middle of a 10' straight edge is about 1/2". Whats the best way of fixing this?
PS I am using schluter shower kit (waterproofing membrane) on green board
Tom
Tom
Unread 05-28-2019, 12:38 PM   #21
Radas
Tile Newbie
Hello Tom,
Wouldn't hurt to add another 2x4 or two to each corner to help with attaching the drywall or add more blocking where you plan on installing grab handles, shower door hinges, etc...
Also, while you're at this stage, it's a good idea to make sure your shower walls are both plumb and flat, it will take a little longer to do using $5 cardboard drywall shims from your local big box or additional 2x4s if necessary. That will make your tile job go a lot smoother.
Ali
..a new excuse to hoard tools
Unread 05-28-2019, 04:19 PM   #22
jlbos83
Really Cool Weekend Warrior
And you would be better off to use plain white drywall, rather than greenboard.
Jeff
It's a DRY heat!
jlbos83 is offline   Reply With Quote
Unread 05-28-2019, 04:25 PM   #23
I agree with Ali and Jeff, Tom, you need more "blocking" for the (any) wall board.
The last pic you posted; back wall, bottom left and right corners; there isn't anything there to which you can screw the wall board to.
Unread 05-28-2019, 04:34 PM   #24
Tom, it'll help if you'll keep all your project questions on one thread so folks can see what you're working on and what's been previously asked and answered. A moderator can give it a more generic title any time you'd like to suggest one.
A geographic location in your User Profile is often helpful as well.
I'll add a second vote to eliminate the MR board and use plain drywall in that room unless your local code compliance people require differently. You can show them that the ICC ES Report that shows the Kerdi System can be used with plain drywall in wet areas.
Unread 05-28-2019, 07:02 PM   #25
fordperson
CX, that makes sense. Thanks for merging the threads.
Ill put up drywall instead of the MR board as advised.
With the corners being so far out, do you guys think I should just rip all the existing drywall out and redo? If so do I need to install any corner bead or tape or do I just tile over the drywall as is?
Biggest concern I have is the corner of the shower up toward the ceiling. It's bumped out quite a bit.
Thanks for your help
Tom
Tom
Unread 05-28-2019, 07:06 PM   #26
Radas
Tile Newbie
It will be easier in the long run to level and plumb your walls and add 2x4s when you rip out all the drywall. Another advantage is that you can stand up 4x8 sheets or 4x10 sheets of drywall and zip them on pretty quick if you start with a clean slate.
If you use kerdi and tile up to the ceiling, you won't have to do any drywall finishing.
Sent from my Pixel 3 using Tapatalk
Ali
Unread 05-28-2019, 07:37 PM   #27
fordperson
sounds like a plan, Thanks!
Tom
Unread 05-29-2019, 09:17 AM   #28
houndzilla
I'm not sure why you guys are posting excerpts from the International Plumbing Code (IPC).
Tom has stated that he's in Illinois and has already posted sections from the Illinois Plumbing Code. Illinois has its own plumbing code that supercedes/replaces the IPC.
Tom to answer some of your earlier questions, yes you read section 890 correct in that your shower waste outlet (drain) needs to have a 2" line, so good on you for correcting it and doing it the right way.
How are you resolving the two vents for the new shower and the existing toilet? Are you connecting the shower vent to the existing vent as some point, or are you going to run the shower vent through the roof?
George
houndzilla is offline   Reply With Quote
Unread 07-16-2019, 03:11 PM   #29
fordperson
houndzilla: thanks for your reply. Thankfully this part of my project is done. I ended up running everything in 2" and ran an independent vent pipe for each(much as it was before the 1.5->2" upgrade).
One more question for you guys, I ended up redoing the whole floor as it was way too wavy. I had 3/4" height differences between the low and high spots.
I ended up ripping everything out, drywall and the floors, adding new framing where necessary and I think its as good as it gets.
Now that I am setting the shower tray, The floor has a tiny bit of slope (1/16 over 5') it shows up ever so slightly if I put a level on the floor.
do you guys think I can just set the tray in thinset and level it that way?
Thanks all!
T
Tom
Unread 07-16-2019, 07:12 PM   #30
PC7060
PC7060's Avatar
IMO, 1/16 over 5’ is perfectly fine! Certainly less than the standard 1/4” per ft slope of the tray.
Moving shower drain and toilet drain ques? iagaoe Tile Forum/Advice Board 11 08-13-2008 12:48 PM
Rough plumbing for toilet flange is too high BlueCanyon Tile Forum/Advice Board 23 09-14-2007 04:51 PM
Adding new ceramic tile under toilet Onnie Clem Tile Forum/Advice Board 2 01-29-2007 08:48 PM
Any plumbers care to comment My toilet waste plumbing question??? Bigboxer Tile Forum/Advice Board 3 04-18-2005 10:49 PM
Toilet Flange & Plumbing Todds Tile Forum/Advice Board 17 10-13-2003 09:49 PM
