Unread 12-28-2015, 07:19 AM   #1
LarryM13
Stacked Stone Shower
Hi all,
I'm putting a shower in my basement over the next 6 months. I'm currently doing the plumbing.
My wife picked out the following as a design inspiration.
I haven't been able to find an exact match for the above (if you know, please tell me) In an effort to find a similar stone, I believe this is an option http://www.eldoradostone.com/product.../#/black-river
Right now, I am framed 64 3/4" X 40" (odd size as I was building around an ejector pit)
The big question, how do I waterproof the shower for the stone wall? Do I use Durock Cement Board, Kerdi Board, Cement Board plus Kerdi Membrane, or something else? What type of adhesive would I use to secure the stone to the wall?
Thanks for your help!
Larry
Last edited by jgleason; 12-28-2015 at 08:07 PM. Reason: please attach photos directly to the forum
LarryM13 is offline   Reply With Quote
Unread 12-28-2015, 08:10 AM   #2
Hi Larry,
Any of the surface waterproofing methods you mention will work.
You know that wall will be impossible to clean, I suppose.
Unread 12-28-2015, 10:24 AM   #3
dbitton
Professional Stoner
dbitton's Avatar
Wow
That'll be an awesome shower!
The stone looks like slate to me, might get it from a quarry, it doesn't look like a veneer to me.. The rest of it could probably use a porcelain slab material for something like this, super cool ideas.
dbitton is offline   Reply With Quote
Unread 12-28-2015, 12:55 PM   #4
Originally Posted by John Bridge
...that wall will be impossible to clean, I suppose.
What John said. If that back wall gets even a little wet with each shower, it's going to accumulate soap scum in the extremely rough surface texture (and soap scum and mold in what appears to be dry stacked/ungrouted joints) that will be impossible to clean.
Unread 12-28-2015, 01:44 PM   #5
LarryM13
Thanks all!
I agree, it will be impossible to clean. The shower will be in my basement and will likely be used less than a handful of times a year. It's more of a design feature, but I still want to waterproof the section correctly.
Larry
Unread 12-28-2015, 01:51 PM   #6
LarryM13
Dbritton,
I don't think it is a stacked stone either, you're probably right in it being from a quarry.
We'll end up going with a veneer to make life a little easier on me though
Larry
Unread 12-28-2015, 02:06 PM   #7
LarryM13
What would I use to set the stone on the wall?
Larry
Unread 12-28-2015, 04:13 PM   #8
Any decent thinset should work. 254 would be bullet proof
Unread 12-28-2015, 05:39 PM   #9
Captain_Slow
Captain_Slow's Avatar
We call that style of tile "split-face" in the UK.
They are predominantly slate, a nightmare to manage in a wet area and waterproofing/tanking is an absolute must. I seal them with a spray sealer as it is easier than using a brush (obviously)....
Daz
Daz
Captain_Slow is offline   Reply With Quote
Unread 12-28-2015, 08:36 PM   #10
K_Tile
Member of Million SF Club!!
Basalt stone
Unread 12-30-2015, 06:34 AM   #11
WestHills
WestHills's Avatar
Just clean it with a power washer once a month.
Justin
NTCA member
WestHills is offline   Reply With Quote
Unread 12-30-2015, 08:03 AM   #12
141pm
We call it Ledger Stone, comes on mesh backed sheets. Ours can't be grouted, so a shower install would be questionable. Let me know if you need pricing/availability. (comes as pictured and in solid gray.)
Richard
141pm is offline   Reply With Quote
Unread 12-30-2015, 08:04 AM   #13
141pm
pic below
Richard
Setting Stacked stone Vic-ter Tile Forum/Advice Board 5 10-13-2015 10:54 PM
Which Adhesive for Stacked Stone Creato Tile Forum/Advice Board 13 08-20-2015 05:39 PM
stacked stone veneer joeperi Tile Forum/Advice Board 1 07-23-2013 04:26 PM
Stacked stone cleaning JoeC Cleaning, Restoration and Sealing 1 07-10-2012 05:25 PM
slate and stacked stone KWIKSIX Tile Forum/Advice Board 10 07-16-2011 04:23 PM
