Unread 04-16-2012, 10:02 AM   #1
Dingus
toilet flange problem
Hi
I Just tiled a small bathroom floor in an old house.
I am planning to install my toilet flange on top of the tile.
However, when I installed the ABS flange only one side sits nice and flush with the tile. The other side sits about 1/4 inch above the tile. I was thinking of cutting copper pipe and using as shims on the side that is not making content with the tile floor
I have not screwed it in place yet and would run the screws through the copper pipe.
Any advice?
Thanks in advance.
Joe
Dingus is offline   Reply With Quote
Unread 04-16-2012, 10:23 AM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Sounds like the tile is pretty uneven which will affect how the toilet lands on the floor as well. Toilet doesn't have to be dead level, but close is good.
If you can get three of the four screws in without shims, you could use stainless steel or plastic washers rather than copper pipe...more bearing surface with the washers. Flange must be stable and not distorted.
When you set toilet use shims to prevent it from rocking around. Any movement will break wax seal. To eliminate what I consider to be the weak link in toilet installation, I like these:
http://www.fernco.com/plumbing/wax-free-toilet-seal
If you're reusing old toilet, you must spotlessly clean the area around the horn where the Fernco glues on. I go so far as to wipe the are with denatured alcohol even on new toilets.
Peter
Unread 04-16-2012, 10:46 AM   #3
You can also use a Sani-Seal gasket instead of a wax ring. Shim the toilet with plastic wedges and caulk the base leaving a gap at the back of the toilet in case of a leak
Unread 04-16-2012, 03:35 PM   #4
Sounds like your riser pipe is not plumb! Is the abs flange all plastic? Plumber's much prefer those with a SS ring, rather than the all plastic ones, as they are stronger. Which would you rather have holding the toilet to the floor, a bolt in a weak plastic notch or in some SS metal? Compound that by not anchoring the flange well, and you're at risk.
Now, how best to fix it depends on what access you have. On some toilets, a flange sitting 1/4" up in the air would prevent the toilet from properly sealing - first, the all plastic flanges are typically thicker than those with the SS metal rings, and then some newer toilets don't have that deep of a well for the wax in the first place.
First, I'd verify that the toilet can be set in place without the wax and not rock on the flange (ie. the flange does not hold it up in the air). If it can set flat, then you have some choices: fix the flange so it can sit flat, or hope for the best.
Toilet Closet Flange problem Army1 Tile Forum/Advice Board 29 09-26-2010 03:50 PM
Toilet Flange romanf Tile Forum/Advice Board 1 01-20-2010 10:12 AM
Toilet flange problem tht828 Tile Forum/Advice Board 2 05-23-2009 10:25 AM
Toilet Flange MikeInCali Tile Forum/Advice Board 2 02-12-2008 12:05 PM
Toilet flange JONATHANPRICE Tile Forum/Advice Board 5 12-13-2005 10:36 AM
