Unread 04-17-2014, 12:58 PM   #1
emmae
Shower Pan Drain Level
I just completed my first shower pan (preslope deck mud, liner and top layer deck mud) and my drain is flushed with the top layer deck mud. This means that my drain will be lower by the size of my tile and thinset. Should I be concerned?
Emma
Emma
emmae is offline   Reply With Quote
Unread 04-17-2014, 01:09 PM   #2
Welcome, Emma.
Yes.
Your drain should be just a tiny bit (1/32nd of an inch or so) lower than your shower floor tile.
You need to unscrew your drain to that level before tiling.
Unread 04-17-2014, 01:09 PM   #3
Richard Tunison
Retired Tile Contractor
Hi Emma and welcome.
You want the drain top to be just a tad below the tiles. How thick are the tiles?
You can try to screw the drain barrel up or there are drain extenders that can raise the height of the strainer.
http://www.stonetooling.com/Extend-O...p/40-00179.htm
Richard
Richard Tunison is offline   Reply With Quote
Unread 04-17-2014, 01:10 PM   #4
Richard Tunison
C.X. is back.
Richard
Unread 04-17-2014, 01:26 PM   #5
emmae
Thanks all for your response and advise. I thought of screwing the drain to make it higher, but afraid that it might cause a leak. The idea of drain extension is not bad either.
Once again, many thanks,
Emma
Emma
Unread 04-17-2014, 01:34 PM   #6
Richard Tunison
Screwing the drain up will not cause a leak. Hopefully you have enough threads left on it to do so.
May I ask how you waterproofed your shower walls?
Richard
Unread 04-17-2014, 01:41 PM   #7
emmae
I should have enough thread left to screw it up a bit. I used 1/2" HardieBacker Cement Backerboard for the walls, taped the sims with fiberglass mesh and thinset, and painted the whole wall and floor with red guard.
Emma
Unread 04-17-2014, 01:43 PM   #8
emmae
I also have Oatey Shower Pan Liner between the preslop and the final deck.
Emma
Unread 04-17-2014, 01:54 PM   #9
04Rdking
First, I ain't no pro.
All sounds good but the Redgard on the floor.... Will let the pro's chime in on that.
Shouldn't be a problem to unscrew the drain a few turns unless the deck mud has hardened..
Bill
Not a pro but avid DIYer.
Why pay when I can do it myself?
04Rdking is offline   Reply With Quote
Unread 04-17-2014, 02:03 PM   #10
Richard Tunison
Good catch Bill.
Emma, the last thing you wanted to do is apply Redgard to the shower floor. You have eliminated the purpose of the porous mud bed and liner and created a "moisture sandwich".
See if you can't peel it up.
Richard
Unread 04-17-2014, 02:05 PM   #11
emmae
I will try peeling it off before tiling the floor. I think I can peel it off. I hope I can peel it off. Thanks for the catch.
Emma
Shower Drain Not Level In Slab Fizziks Tile Forum/Advice Board 8 01-08-2010 10:54 AM
Shower Drain Not Level LivermoreMP Tile Forum/Advice Board 3 07-08-2007 11:04 AM
Tiling when shower pan is not level (old house) rmx2501 Tile Forum/Advice Board 8 08-24-2006 11:21 AM
Pan Liner done and Drain not level Tampal Tile Forum/Advice Board 1 05-16-2006 05:42 AM
Shower drain not level Westie Tile Forum/Advice Board 21 03-12-2004 11:01 PM
