Unread 12-10-2019, 04:41 PM   #1
brandonw
Custom Shower Looks Butchered :(
I've been lurking and reading and time is on my side with this but here goes. I'm remodeling everything in my house to my liking and have worked my way to the master bedroom bathroom. I knew it would be bad based on everything else but I'm scratching my head with what to do with this. They screwed cement board to the ledge in the shower pan and the crappy tile-work leaked through and of course leaked through the membrane that they screwed through. The wood is wet not rotten. I can repair the screw holes with "The Right Stuff". We bond PWC pump shoes to the hull with it and it never comes loose. The pan isn't exactly sloped right as water sits in the upper right corner.
The question here is... Since it's a custom size and I'm an amateur should I gut it and start fresh or repair the crap job and work with whatever pan is hiding below?
The next question would be do I go with a kerdi membrane and drain if it's a complete gut? What would you do if this was your shower?
Brandon
Thanks for helping me! If you need any computer advice/help or digital security help just ask.
brandonw is offline   Reply With Quote
Unread 12-10-2019, 05:02 PM   #2
Welcome, Brandon.
One of the more common mistakes we see in traditional shower receptor builds and one we warn our visitors about regularly. By "ledge" I'm presuming you mean the top of the shower dam, right?
I would recommend you completely gut the bathroom, or at least the shower area, and start fresh with a new shower.
You can do another traditional shower receptor or a direct bonded waterproofing membrane type shower. Either will serve for decades if done properly. I personally prefer the direct bonded membrane method.
Unread 12-10-2019, 05:35 PM   #3
brandonw
Thanks for the reply. One more question. Can the schluter kit be trimmed to fit this shape? It has to be this shape for shower entry
Brandon
Unread 12-10-2019, 05:56 PM   #4
makethatkerdistick
Yes, the Schluter tray and or curb can be trimmed to fit. You can also add on a section with deck mud next to the tray if required.
I built a shower with a similar footprint. I used the Kerdi membrane and corners but didn't bother with the tray or curb both of which I elected to construct myself from cheaper materials. In doing so I saved money and could easily give the mud bed the exact shape I wanted. Also, nothing wrong with building another curb from wood covered with a suitable material to which the Kerdi will attach (or just bricks bonded with thinset if you're on a slab). I love the Kerdi system but personally think that a mud bed is nicer and sturdier than those foam trays. Both will work, however.
Wolfgang
Unread 12-10-2019, 06:56 PM   #5
You can go back with any method you feel comfortable using but definitely start over.
Unread 12-10-2019, 07:18 PM   #6
Welcome to the forum, Brandon!
Yeah, I agree with starting over. Here on the forum, were happy to take you through the entire process of remodeling with as little or as much help as you need. We like to help.
Unread 12-11-2019, 05:54 AM   #7
brandonw
thanks everyone. I'm going to pull the curb and knock up the top layer of thinset/tile and see what's what. the bathroom will be stripped down to the 2x4s for inspection. Found a bunch of ants and some tiny palmetto bugs in the curb last night which is great
Brandon
Unread 12-11-2019, 06:28 AM   #8
brandonw
welp... It's a giant slab and I would need a jackhammer to break this apart. My air chisel won't touch this.
How bad would it be to break up the tile, add to the slope, rebuild the curb, seal it and be done?
Brandon
Unread 12-11-2019, 07:49 AM   #9
brandonw
Nevermind. A point chisel and the air chisel get in pretty good and a mallet is making decent work. This will be a full 8hrs of work but I never want to do this crap again.
Brandon
Unread 12-11-2019, 10:39 AM   #10
brandonw
Well that happened fast. It's all rotten... This shower was 5 years old. They "redid" it when they pinned the house foundation. Pretty sad.
Brandon
Unread 12-11-2019, 11:58 AM   #11
I think your plan of taking that entire bathroom apart is a good one, Brandon.
Unread 12-12-2019, 03:45 PM   #12
brandonw
Okay I do need some advice as to what to do with this drain? I'm buying the Schluter kit and need this drain out. I put a ceramic heater on it for 20 minutes and still couldn't budge it.
Side note I have to bring the left side up 1/4" and taper it level to the drain Walls are square though
Brandon
Unread 12-12-2019, 03:58 PM   #13
Is that black plastic pipe down there, Brandon? Appears that someone glued a PVC drain flange to ABS (black) pipe. Not recommended.
But yeah, it needs to come out, and a heater isn't going to do the trick. What you will need is an inside pipe cutter (google; big box stores have them for about 10.00). Once it's out you'll see if there's enough space between the concrete and the black pipe (aka "riser) to which to can attach a coupler and another section of ABS pipe to the height you'll need to accommodate the new pan and drain assembly.
Unread 12-12-2019, 04:09 PM   #14
brandonw
well crap. Yes that's black pipe down there I'll google the inside cutter and directions. Thanks for the tips again! I'm sure I'll have another question later on.
Brandon
Unread 12-12-2019, 09:32 PM   #15
If the riser is not plumb, trying to get the Kerdi drain to be, is near impossible. You might need to crack some concrete and deal with the pipe so you can get the riser plumb. There is a little bit of flex if you use a liberal amount of cement on things (this actually melts the plastic), then hold it perfectly plumb. It can take awhile, as it's designed to try to equalize the pressure, which would make it move back to being tilted until it evaporates all of the solvents...in the interim, it's 'mushy'. It might take some weights and carefully positioning things. With the ABS pipe, you might want to swap your pvc drain for the abs one. Transition cements aren't allowed everywhere for a reason...they're less than optimal.
Depending on the intended height of your pan, you MIGHT still be able to leave that in place and use their conversion drain. THat assembly does have a little bit of flexibility as things seal with a rubber collar.
If the drain isn't exactly where you want, this would be the opportunity to move it.
custom levelquick over custom peel and stick membrane Big Joe Tile Forum/Advice Board 7 12-15-2012 10:17 AM
Custom Shower - Need some confirmation on bisazza shower install MyFirstShower Tile Forum/Advice Board 17 12-13-2009 09:06 PM
I think I butchered the install... Edthedawg Tile Forum/Advice Board 21 07-04-2009 04:37 PM
Custom Building Products Custom Blend CharlesW Tile Forum/Advice Board 15 02-20-2009 11:51 AM
My first custom shower annieef Tile Forum/Advice Board 5 09-26-2003 01:25 PM
