Unread 12-23-2010, 01:10 PM   #1
tile dale
California Tile Man
KerdiBoard issue
I am currently working on an exterior fountain for a client. I've installed 2" KerdiBoard across the back corner to house the pump and hoses. The issue that I'm having is the membrane has separated from the core in two places. It's a little concerning!
Have any of you run into anything like this? Any ideas?
I ended up cutting a slit in the separated area and "Kerdifixing" the flaps back down. Will this be the solution? Will the entire face of this thing separate?
Dale
tile dale is offline   Reply With Quote
Unread 12-23-2010, 01:16 PM   #2
Topspin
SchluterUgrad
Topspin's Avatar
Man, I'll bet Schluter will be all over that. In my purchases and at our local distributor I've never seen any delamination yet. Once JB weighs in we'll all see what the fix should be. Also let us know what Schuter says too. Call your rep - likely Dan Curtis 707-888-8531
Unread 12-23-2010, 04:31 PM   #3
johntrent
I had something similar but found out it was my own doing. I used KB to do my countertops and before I installed the tiles we used them for a week or so. Ended up cooking breakfast using a large griddle. Afterwards under the griddle there was a bubble - delaminated area probably 5-6" across by 3-4". I ended up slicing it open - kerdi fixing it back down. Tops have been in for couple of months now with no problems.
I also believe that Schluter doesn't want the board in direct sunlight such as for an outdoor kitchen.
Did you subject the board to any type of heat?
John
johntrent is offline   Reply With Quote
Unread 12-23-2010, 05:23 PM   #4
RanCar
Had the same thing happen to me on some pcs that were sitting on my trailer. Turns out that this is an issue when the board is exposed to direct sunlight or so I have been told by Schluter.
I looked thru my Kerdi -Board literature and there is a disclaimer from Schluter that says the board must not be stored outdoors where it is exposed to direct sunlight or weather.
That would indicate to me that the product is not rated for exterior use, but I could be wrong.
Randall
RanCar is offline   Reply With Quote
Unread 12-23-2010, 05:34 PM   #5
i dont think once the kerdiboard is covered with tile it would matter if it was outside.
just not outside uncovered.
Unread 12-23-2010, 05:54 PM   #6
Topspin
SchluterUgrad
Topspin's Avatar
Talk about customer service - I called Schluter Rep to tell him about the above situation. He got a hold of Tile Dale and sounds like that issue is licked. I'll wait to see what Dale has to say, but it was nice of Dan (Schluter Rep) to dive in, handle it, and then even let me know the current status.
Fine Customer Service. Thats what I build my business on and I LOVE to see it in other companies - My favorites:
Laticrete
Schluter
TLS (Mick)
Master Wholesale/RPM Mats (Seattle)
REI - Recreational Equipment Inc.
Nordstrom
FedEx
and the list goes on.
Thanks for your great service - Merry Christmas
Unread 12-23-2010, 06:12 PM   #7
tile dale
California Tile Man
Yes, Dan called me back right away and assured me that my fix was good. He said that it'll be fine.
Dale
Unread 12-23-2010, 07:36 PM   #8
gueuzeman
That's great. But WHY did it happen in the first place?
gueuzeman is offline   Reply With Quote
Unread 12-23-2010, 07:45 PM   #9
tile dale
California Tile Man
He said that it was an early version board with uv sensitive adhesive. He said "Cover it up"
Dale
Unread 12-23-2010, 09:29 PM   #10
Honeydo
uv sensitive adhesive.....
should of used a modified
Ed
Honeydo is offline   Reply With Quote
Unread 12-23-2010, 10:38 PM   #11
gueuzeman
What Ed said- 254 rapid.
Unread 12-30-2010, 10:12 AM   #12
JC
hmmm...
Well until I know exactly what causes this and how it has been fixed and am convinced it has been fixed and not just switch glues and see what happens next kinda fixed..i aint using the product..point blank.
I mean whats it going to do over extended time? How do we know plasticizer migration/shrinkage does not contribute to this problem? Or how do we know this glue is plasticizer resistant enough to handle oils leaving the cpe. How do we know the new glue is good enough?
Im not going thru the tile over mastic and green drywall stuff again..or the moldy hardie board BS again. Call me a pessimist but Ive seen so many products turn out to be crap in the last thirty years i am not going to believe any manufacturer by blind faith..I don't care if it has a 200 yr warranty.
Having some mystery glue go bad and switching to some other mystery glue..just does not cut it or give me any confidence in this product..and unless I feel good about it..im not using it in someone else house...sorry but im not taking any chances
JC is offline   Reply With Quote
Unread 12-30-2010, 11:56 AM   #13
eurob
Not...Sure
If a product reacts this way , there is no way you can repair it right.
Removal of the product is called for. There is very little chance , especially in your application , for a long lasting installation.
Roberto
Unread 12-30-2010, 08:29 PM   #14
Hammy
Hammy's Avatar
I'm interested in the out come of the problem.
Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
Unread 12-30-2010, 08:30 PM   #15
and
Kerdiboard Shower advertguy2 Professionals' Hangout 44 11-30-2010 07:48 AM
Experience with kerdiBoard/Similar and Large Format tiles? ModReno Tile Forum/Advice Board 1 10-27-2010 07:42 AM
Is this an issue? GeronimoDF Tile Forum/Advice Board 19 03-06-2010 12:42 PM
Been a while... still having same issue... NastyBurn Tile Forum/Advice Board 92 12-26-2007 09:06 PM
