Unread 09-08-2009, 02:52 PM   #1
pvrc24
Waterproofing my shower walls before tiling
I am tearing out my bath & shower combo and replacing it with a shower only. I would like to know if I use a fiberglass board would I have to use a sheet membrane also? Or, would using just the cement backerboard, and tile be enough? I was planning on using the cement backerboard then the Schluter System wall membrane, but some tilers at the home depot store told me not to do that, I want to make sure I don't have any water leaks in the future. Also where in Houston, Texas can I find fiberglass board?
Regards,
Lola
Lola
pvrc24 is offline   Reply With Quote
Unread 09-08-2009, 03:00 PM   #2
Lola,
if you are ripping out your walls and shower floor and redoing you can use Kerdi on the wall and floor. you can use drywall on the shower walls and do a mudbed on the shower floor.
using drywall behind the Schluter Kerdi is acceptable since when done right it will never see water.
Waterproofing behind shower walls? ifletchr Tile Forum/Advice Board 5 07-06-2008 07:22 PM
Waterproofing shower walls. rusty_5620 Tile Forum/Advice Board 2 02-26-2006 11:40 PM
Waterproofing Shower Walls HandyGal Tile Forum/Advice Board 17 03-17-2005 11:58 AM
Waterproofing tub/shower walls? Sofia Tile Forum/Advice Board 10 02-21-2004 04:45 PM
Waterproofing behind shower walls Leigh Tile Forum/Advice Board 13 03-05-2002 07:45 PM
