Unread 04-11-2021, 04:56 PM   #1
californiahomeowner
Is my mosaic backsplash grout joint space uneven?
Hi I am a homeowner and directly hired a licensed tile guy to install my kitchen backsplash. They are marble mosaic pieces. He told me that the marble pieces on the sheets had uneven grout joints and did his best to even out the grout joint space. Since it was a backsplash, he said he didn't need to make the walls perfectly plumb and corners square. I think the walls were mostly plumb and square to begin with.
It looks OK to me, for the most part, but obviously there are many joints that are uneven. It is not grouted yet. I'm just trying to figure out if this is an acceptable job? It took him a day for ~37 square feet of backsplash so far. Obviously, all the pictures on the internet and in stores show perfect grout joint spaces on a backsplash or tile.
I am on the anal/neurotic side.... This is my first time getting a backplash installed so just trying to set a reasonable expectation and reference point in terms of what is an acceptable job.
TY.
californiahomeowner is offline   Reply With Quote
Unread 04-11-2021, 06:40 PM   #2
Lazarus
Lazarus's Avatar
From the pics...looks like a pretty credible job.....
Unread 04-11-2021, 06:51 PM   #3
Grout, unless it's a highly contrasting choice, tends to hide minor imperfections. In a quick look, I don't see sheet-to-sheet joints that are a more common complaint. Sometimes, those are quite obvious and grouting won't fix it.
Unread 04-11-2021, 07:25 PM   #4
With the uneven reflections I seem to be seeing in the photos, I’d double check to see if the tiles are relatively flat....or relatively tilted every which way. If the light source producing the reflection is a small light bulb, it might be perfectly fine. But if it’s a window, I’d investigate.
Unread 04-11-2021, 09:00 PM   #5
Snets
Professional Weekend Warrior
Snets's Avatar
I just happen to have a sheet of very similar tile here in my home office that I will be using soon. I grabbed my dial calipers and did some quick grout line width measurements. I picked the visually widest and narrowest spaces and measured, The most I could come up with is 0.018" difference....but you can see it.
Unless there is a ton of lippage, I think once it is grouted it will look good. i remember someone here once saying he never showed a customer a tile job before grouting if he could help it.
Hopefully, this is the case here.
Snets
My FIRST Kerdi Shower Project
Always look in the LIBERRY
Unread 04-11-2021, 09:27 PM   #6
californiahomeowner
Thanks for the advice!
Unread 04-12-2021, 10:43 PM   #7
Snets
Snets's Avatar
Let us know how it turns out. Post some pictures, please.
Snets
New tile installation - uneven space LadyReddy Tile Forum/Advice Board 12 10-19-2017 09:05 AM
Grout for marble tile backsplash with 3/16" space Bobtail2 Tile Forum/Advice Board 19 07-18-2017 07:42 AM
Mosaic backsplash on very uneven surface JulianneB Tile Forum/Advice Board 1 04-01-2011 11:52 PM
Backsplash grout joint too big. Michigan Mike Tile Forum/Advice Board 1 03-04-2006 05:13 PM
Tub to cbu joint space walktall Tile Forum/Advice Board 2 11-15-2004 07:25 AM
