Unread 03-10-2021, 07:53 AM   #166
Adding a second layer of ply is about the only way to make up for the between joist deflection deficiencies of the first layer.
In your case, though, 1/2" ply will do the trick when properly installed. You want that 1/2 ply to have a face grade no lower than C, and be laminated with moisture resistant glue, typically referred to Exposure 1 or EXP 1. 1/2" B/C EXP1 ply is pretty common at the BBS's.
Unread 03-10-2021, 09:19 AM   #167
markch
Then Lots of screws + construction adhesive between layers?
Mark
markch is offline   Reply With Quote
Unread 03-10-2021, 09:26 AM   #168
Here is a good article from our Liberry showing what I consider the best way to install that second layer of plywood, Mark.
And no, Dan is not suggesting you glue the second layer to the first, he's pointing out the requirement that the second layer be an exterior glue type plywood. Use the mechanical fastener schedule shown in the article above. If you want to glue, do not use a construction adhesive from a tube. You would need a full spread of wood glue for that purpose and then only if the surface of your first layer of subfloor is plywood and in near pristine condition. Best to forego the glue all together, 'specially if you're starting with OSB as I suspect.
Unread 03-10-2021, 01:41 PM   #169
markch
VERY informative article -- "The idea presented herein is to have two layers of sheathing at those points where the bending stresses are greatest—over the joists."
Mark
Waterproofing and Tiling a Drop-in Tub that in a shower. Jacob Smithg Tile Forum/Advice Board 1 11-03-2020 06:09 PM
Re-tiling/waterproofing old plaster walls tilenoobie0 Tile Forum/Advice Board 3 06-15-2019 09:18 PM
Need help waterproofing and tiling pool, not on concrete. njannsen Tile Forum/Advice Board 13 05-14-2014 03:29 PM
Method of Tiling Wall and Waterproofing? cb9209 Tile Forum/Advice Board 25 09-03-2010 06:02 AM
Waterproofing my shower walls before tiling pvrc24 Tile Forum/Advice Board 1 09-08-2009 03:00 PM
