Unread 11-02-2020, 09:49 PM   #1
Jacob Smithg
Waterproofing and Tiling a Drop-in Tub that in a shower.
I'm in what I see to be a unique situation. The homeowner is wanting a drop-in whirlpool tub inside of a shower stall, with half of the stall being tub and the other half shower. The width of the stall is not much more than the tub itself, leaving almost no room on the two short sides of the tub for waterproofing, much less tile. The tub's installation guide mentions decking over the side of the tub by a small amount with tile. Is that possible? If so how could that be waterproofed. my thought is to build the surround level with the tub and then mortar any gaps and then redguard over that overlapping onto the tub itself to bond not just to the mortar. The tub had already been set in place and siliconed around the perimeter to the concrete board already in place.
Jacob
Jacob Smithg is offline   Reply With Quote
Unread 11-03-2020, 06:09 PM   #2
Just to make sure, you're saying the tub is sitting beside the shower and no water spray from the shower will hit the tub deck?
If spray from the shower will hit the tub deck, I'd want to add a tub flange to the tub using epoxy to bond it with. I've heard about this type of flange but have never done it.
You'll have to be careful, this has a chance of being a bad situation.
Need Help Waterproofing Drop in / Shower Christian23 Tile Forum/Advice Board 12 04-15-2014 05:35 AM
waterproofing drop-in tub deck for granite covering jjdike Tile Forum/Advice Board 22 10-08-2013 08:16 PM
Waterproofing my shower walls before tiling pvrc24 Tile Forum/Advice Board 1 09-08-2009 03:00 PM
Waterproofing drop-in tub for possible future shower conversion TotalNewbie Tile Forum/Advice Board 12 12-30-2007 05:48 PM
waterproofing drop-in tub with shower over it sojay Tile Forum/Advice Board 1 06-28-2005 02:47 PM
