Unread 03-12-2019, 11:07 AM   #1
Schluter shelf
These are out in the 2019 Schluter catalog:
Schluter shelf
Unread 03-14-2019, 08:39 AM   #2
A great idea, I think. It's certainly a new direction.
Unread 03-14-2019, 07:45 PM   #3
makethatkerdistick
Saw those and like them.
Schluter shelf? Looks too properly spelled (as opposed to the "Schulter" variation). How about a Schluter schelf? Or a Shluter schelf? Or even a Shluter shelf?
Wolfgang
Unread 03-15-2019, 07:05 AM   #4
HS345
Tile Contractor
HS345's Avatar
Wow, very kewl. I'm surprised they didn't think of this sooner.
The name's Greg
Unread 03-15-2019, 07:51 AM   #5
mullet
mullet's Avatar
Now that is a great ideer, I want one in 316 SS.
chuck
my first Kerdi Shower
Unread 03-15-2019, 03:06 PM   #6
makethatkerdistick
Chuck, why 316SS? I've never seen 304SS corrode under normal circumstances, even with hard water and decades of exposure.
Wolfgang
Unread 03-15-2019, 04:23 PM   #7
mullet
mullet's Avatar
Its a knee jerk reaction I guess being in a marine salt water area.
chuck
Unread 03-15-2019, 06:15 PM   #8
makethatkerdistick
The Kerdi linear drain body and frame are 316SS. If anywhere, there it makes more sense as the channel might remain slightly wet at all times since it's covered up and doesn't dry out readily.
Also, most of the trim is available in 304 or 316. I never thought about getting 316SS trim for my shower projects as the 304 was already prohibitively expensive. I think the step up from aluminum to 304SS is much more important and reaps you more benefits than from 304 to 316. But yes, in marine applications 316 is longer lasting.
Wolfgang
Unread 03-15-2019, 08:10 PM   #9
mullet
mullet's Avatar
It doesn't leave rust drip stains on the fiberglass hulls.
chuck
Unread 03-15-2019, 09:14 PM   #10
smifwal
I am with mullet on this one, all of my salt spreaders are made of 304SS(the cheapest one they can get) and while it doesn't rust out like the painted steel ones, it does blemish and needs to be polished out to be shiny again
Unread 03-16-2019, 08:39 AM   #11
Stainless fixtures hold up just fine in showers. Everything needs to be kept clean and dry after each use.
Unread 03-16-2019, 01:21 PM   #12
makethatkerdistick
Even my 316SS linear drain cover needs some Barkeeper's Friend treatment once in a while to get rid of the thin layer of efflorescence that builds up over time and that won't come off otherwise.
Usually, 304 should have about 18% chromium and 10 % nickel in it. In some cheaper stainless steels it's possible that there is less chromium in it which would make the steel less corrosion resistant.
Wolfgang
Unread 02-17-2021, 07:36 PM   #13
kevreh
kevreh's Avatar
I just bought two of these to install. I’m a little uneasy about how much weight they’ll support if someone decides to put their hand on it for support. Yes, not their intended use. But seems to me that top part mortared to the wall behind the tile is a high torque point.
Schluter doesn’t want to share weight limits in case someone gets the wrong idea.
kevreh is offline   Reply With Quote
Unread 02-18-2021, 08:13 AM   #14
speed51133
no worse than a typical installation that uses silicone or is paced between tiles. That flange on it that is set into the thinset and behind tiles is strong enough.
I have installed a few of these and love them. I really hate niches, and will always use one of these from now on.
Unread 02-18-2021, 08:34 AM   #15
kevreh
kevreh's Avatar
Good to know you’ve used them and like them. The fact they go behind the tile helps make them strong, but also means more repair if too much weight is put on them. I have to assume it’s a lot more then someone casually leaning on it.
Schluter bench over Schluter shower pan chatterc Tile Forum/Advice Board 4 11-24-2013 12:30 PM
To Schluter or not to Schluter, that's the question... shower KC Tile Forum/Advice Board 8 06-28-2009 02:54 PM
Shelf in a niche jamiep Tile Forum/Advice Board 4 06-02-2008 03:19 PM
Epoxing a Schluter or Schluter like profile pitterpat Professionals' Hangout 8 02-07-2008 06:09 AM
Installing corner shelf over Schluter Kerdi in Shower pstage Tile Forum/Advice Board 8 09-01-2006 03:56 PM
