Unread 10-26-2015, 10:52 AM   #1
umahunter
duckhunter
soaking handmade mexican tiles ??
Well I've been asked to do a tile small tile rug in a bathroom 44x30 with decorative handmade mexican tile with the red clay base over concrete simaler to the pic you know the unsquare kind . up until now I've used a handful of these tiles as single insets here and there never a bigger section. what I'm trying to figure is if I need to soak these tiles a bit beforehand for best adhesion can't get a hold of the maker and just wanna make sure it's done right thanks for any input
Garret -Garcia's painting and renovation
umahunter is offline   Reply With Quote
Unread 10-26-2015, 06:12 PM   #2
Lazarus
Lazarus's Avatar
As they tend to be "Absorbive," you can certainly soak them for an hour or two before setting them....but I have put up many of this type of tile without that....
Unread 10-26-2015, 06:27 PM   #3
Back in the day of "wet set" installations, we had a bucket of tepid water with tiles soaking in them.
We would rotate dry ones for the pre-soaked ones then give time for the wet ones to drip dry.
They can be damp, but not shiny wet as shiny wet will be a bond breaker.
Unread 10-26-2015, 06:31 PM   #4
Same as Laz, we use to install tons of it and we never soaked them. For installing, I don't see an advantage in soaking. Soaking will help when it comes to grouting, that is if you grout it within a day or two. The moisture in the tiles will keep the grout from drying so fast.
Unread 10-26-2015, 06:32 PM   #5
umahunter
duckhunter
hmm
I did end up soaking them for about an hour then let dry for a bit till I thought they were just absorbative enough to set I've set these before but just as and random accent tile here a there never a big section these tiles are quite fun to set lol not a single square tile in the bunch varied as much as 3/8 on some but the customer wanted the rustic oddball look so it's cool lol the bad part is butting up straight tiles around them lol
Unread 10-31-2015, 07:10 PM   #6
umahunter
duckhunter
floor finished
Finished the floor
Unread 10-31-2015, 08:03 PM   #7
I like it. Very nice job.
DIY advice for handmade tiles for kitchen backsplash rebaW Tile Forum/Advice Board 3 12-30-2009 02:54 PM
Ceramic tiles soaking up water marywrench Cleaning, Restoration and Sealing 6 02-23-2008 06:46 AM
Mexican Saltillo Tiles – Pool Room – Harden Surface / Tiles smooth_player Tile Forum/Advice Board 3 02-20-2007 01:00 PM
tips for handmade (irregular) tiles? evanpowens Tile Forum/Advice Board 5 09-25-2006 10:39 AM
Granite shower tiles soaking water in... Knyte260 Tile Forum/Advice Board 13 06-09-2006 09:04 PM
