Unread 05-12-2013, 11:24 AM   #1
gueuzeman
Kerdiboard fastening- screws
Having trouble locating a galvanized fastener in local shops that has a flared underside to the head like the (expensive and hard to get) Schluter ones.
I''ve just been using exterior deck screws, which work fine, bt the heads don't seat in thye kerdiboard washers as snug. Seems to be made for the shape of a standard drywall screw.
I know, I know, but here's my theoretical question- So on a traditional kerdi install, you hang drywall with drywall screws, right? And the screws are protected, so it's ok, right?
So if I'm protecting the washer and fastener on the kerdiboard, and it's never going to get wet, why can't I use a non-corrosion resistant screw?
And no, I will not be k-banding, but either urethane caulk or 2 coats hydroban.
Currently using ceramic coated deck screws, and happy to continue doing so, just wondering out loud.
gueuzeman is offline   Reply With Quote
Unread 05-12-2013, 11:32 AM   #2
Topspin
SchluterUgrad
Topspin's Avatar
Same feeling, and same method here. But I use sheet rock screws, the thicker ones. Don't know size of screw it's 1 1/4" x ? thick, I just buy the huge plastic box with handle. Wedi sausage tube the tabs, then might hit the bigger ones with a coat of Hydroban to give the smooth urethane some tooth.
Unread 05-12-2013, 11:42 AM   #3
Wouldn't bother me at all, Gueuze, but you won't win any arguments if you have a failure of any kind.
You can get galvanized drywall screws, too, which might make me feel a bit better about it.
I've not tried decking screws on Kerdiboard, but I can see the heads being too thick to work as well as drywall screws or KerdiBoard screws (which look to me like galvanized drywall screws).
Unread 05-12-2013, 12:03 PM   #4
gueuzeman
Couldn't agree more, CX, as manufacturer's directions override industry standards, as the uncoupling/crack isolation debate shows. eh?
The deck screws work fine, and are available . I'm glad to hear that there are galvanized drywall screws. If I can locate some at a reasonable price I may get some.
In the meantime I'll save my drywall screws for the electrical boxes.
Unread 05-12-2013, 02:52 PM   #5
I don't have any problem with drywall screws which have had waterproofing applied over them.
Unread 05-12-2013, 03:27 PM   #6
we normally use the backer on screws since they are handy
Unread 05-12-2013, 06:10 PM   #7
John K
For what its worth I use 1 5/8 sheet rock screws with the Wedi board washers. If water gets through I am up a creek without a paddle anyway, which would negate the type of screw I used.
Not to mention who is really looking to call in a manufacturer when the installation doesn't follow their guidelines to a "T". (ie, Hydroban on Kerdiboard with a little side of Greenskin and topped off with some modified thinset.
John
www.precisiontilestone.com
John K is offline   Reply With Quote
Unread 05-12-2013, 08:32 PM   #8
Our greenhouse
I'm with John, my local daltile doesn't sell the schluter fasteners in bulk; however, they do carry the large buckets of wedi screws and washers which we use for kerdi
Howard
Our greenhouse is offline   Reply With Quote
Unread 05-13-2013, 06:03 AM   #9
World LLC
World LLC's Avatar
galvenized drywall screws...
We have a few sheets to attach to 20 gauge steel... we found 1 5/8 zink self tappers
Matt
www.Facebook.com/worldllc
World LLC is offline   Reply With Quote
Unread 05-13-2013, 06:20 AM   #10
Cain
Cain
I use cement board screws with the kerdi washers when I use kerdi board.
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is offline   Reply With Quote
Unread 05-13-2013, 08:32 PM   #11
Kilauea
LT
Kilauea's Avatar
I used leftover kerdi screws to fasten my outlets on my backsplash todayhahahahhaah....lol-im kidding!!
*L.T.*
tandctile-dot-net
2nd generation tile installer
Kilauea is offline   Reply With Quote
Unread 05-14-2013, 05:21 AM   #12
bctile601
Tile Contractor
bctile601's Avatar
I use the gray 1 5/8" deck screws on Wedi washers.
I keep 2 1/2" and 1 5/8" in bigger boxes on the truck, and have a small box of 1 1/4" and 2".
Fasten cement board with them, studs together with them, HydroBan, Wedi, Aquadefense, Kerdi
Whatever
Brian---
No one cares how much you know until they know how much you care
bctile.com
bctile601 is offline   Reply With Quote
Unread 05-28-2013, 03:43 PM   #13
Mason Tile & Marble
Pride In Craftsmanship
Mason Tile & Marble's Avatar
I use tabbed washers from warehouse bay (item No: 30-40700), identical to Kirdi washers, and $24 for 500. They have coated screws as well!
Todd
www.masontileandmarble.com
Mason Tile & Marble is offline   Reply With Quote
Unread 05-28-2013, 04:25 PM   #14
At a recent workshop, they discussed the difference between waterproof and vaporproof...while the perm rating of Kerdi (or Kerdiband) is in the order of 0.78, it is waterproof...Kerdifix is not the recommended covering for the screws/washers on KerdiBoard. Long term, will it matter? Probably not, but it could.
Unread 05-28-2013, 06:09 PM   #15
Mr.Miyagi
Re-Remodeler & Re-Tiler
Mr.Miyagi's Avatar
Grabber Construction Products:
http://www.grabberman.com/CatBrowser...oC8ss13%2F8%3D
Rodenhouse Washers & Fasteners:
http://www.rodenhouse-inc.com/
Cary
Mr.Miyagi is offline   Reply With Quote
KerdiBoard issue tile dale Professionals' Hangout 44 01-14-2013 08:42 PM
KerdiBoard Problem greywolfarch Professionals' Hangout 50 05-01-2012 06:54 AM
flooring screws vs. deck screws renoyyz Tile Forum/Advice Board 21 03-19-2012 07:41 AM
Kerdiboard Shower advertguy2 Professionals' Hangout 44 11-30-2010 07:48 AM
backerboard - thinset and screws? Or just screws? tkahn Tile Forum/Advice Board 4 03-14-2009 01:06 PM
