Unread 02-10-2013, 10:53 AM   #1
kavasam
kerdiboard to sheetrock at outside corner
Any advice on how to join 1/2 inch kerdi board to sheetrock at outside corner? Shower remodeling & currently studs are exposed within shower area. The shower head wall will be tiled right to edge of an outside corner where it turns 90 degrees/perpendicular to become a painted sheetrock wall. The rock is not a wet area, just the rest of the bathroom. The curb will be flush/in line with the face of the finished sheetrock wall. The shower glass (semi-frameless) will be centered on curb (finished 5" wide marble) and therefore approximately 2 to 21/2 inches from the outside corner where it is attached vertically on shower head wall.
SAM
kavasam is offline   Reply With Quote
Unread 02-10-2013, 03:33 PM   #2
by-eye
I would just install a corner bead, and use a non premixed joint compound, and perhaps thin set on the shower head wall.
Mark
Mark
by-eye is offline   Reply With Quote
Unread 02-10-2013, 07:39 PM   #3
Welcome aboard, Sam.
Ditto. A standard corner bead will work.
Unread 02-11-2013, 06:54 PM   #4
kavasam
Question Thanks for the advice!
Of course..one more question. I plan to use Kerdi rondec bullnose at the edge of the tile. Would the metal corner bead interfere, or cause the corner to build out too far? The rondec fits under the edge of the tile about 1/2 inch & does have some dimension to it, maybe 1/16 of an inch. The build out probably wouldn't be obvious since it would only be about 2 to 21/2 inches of tile showing on the outside of the shower frame/glass.
SAM
Unread 02-11-2013, 07:15 PM   #5
HooKooDoo Ku
Disclaimer: Just a DIYer winging it here:
As best as I can tell, RONDEC is basically corner bead for tile. It's purpose seems to be to make a clean outside corner without using bullnose tile.
But the RONDEC is designed for tile to be on both sides of the bead. But it 1sounds like you want tile on one side and drywall on the other. That seems to mean that when you install the RONDEC, you will want to install it flush with the drywall and simply fill the gap between the RONDEC and drywall.
Joseph
KerdiBoard issue tile dale Professionals' Hangout 44 01-14-2013 08:42 PM
Tile to Sheetrock Transition in Outside Corner oreyes Tile Forum/Advice Board 2 09-24-2008 04:32 AM
Corner Bead over sheetrock, under kerdi, tile JohnP Tile Forum/Advice Board 2 04-03-2007 08:42 AM
corner bead where cbu meets sheetrock? eagleslawyer Tile Forum/Advice Board 1 03-05-2006 07:33 PM
Outside corner meeting sheetrock gar Tile Forum/Advice Board 1 09-13-2005 06:09 AM
