Unread 11-26-2020, 02:51 AM   #1
mike1974
Expansion Joints when doing 33 offset wood planks
Hi Everyone,
Getting ready to lay wood look porcelain tiles in 33 offset. It came to my attention that I need to account for expansion.
I have accounted for the expansion between the wall and tiles (perimeter joints). Do I also need field expansion joints ?
My room is 20 x 30 ft.
mike1974 is offline   Reply With Quote
Unread 11-26-2020, 09:11 AM   #2
Tiger Mountain Tile Inc
You're supposed to have movement joints every 20-25 ft in the field. So it'd be nice to split that 30 ft dimension into two halves.
A movement joint is a grout joint that's filled with silicone rather than grout, FYI. You should fill it with backer rod first then 100% silicone that is color matched to your grout
James Upton
Tired of bullnose tile trim? Here are 5 edge trim alternatives ~DIYTileGuy
Unread 11-26-2020, 11:02 AM   #3
Welcome to the forum, Mike.
...and If the floor is exposed to direct sunlight, the requirement for closer spacing of those joints comes into play due to greater thermal expansion/contraction. Is the floor exposed to direct sunlight?
Control Joints, Expansion Joints, Construction Joints? trevorsimko Tile Forum/Advice Board 2 03-17-2017 10:10 AM
How much LASH with wood planks? dalrock Tile Forum/Advice Board 30 02-28-2015 05:59 AM
expansion joints over wood subfloor thatsflooring Tile Forum/Advice Board 12 08-29-2013 07:43 PM
fully flexible joints instead of single expansion joints JinMTVT Tile Forum/Advice Board 12 02-16-2012 06:08 PM
Question on Cold joints, Expansion Joints for large tiles on Ditra jmondanaro Tile Forum/Advice Board 3 08-01-2011 01:35 PM
