Unread 11-25-2020, 07:56 AM   #1
Mann81
Heated floor advice
Can I use Detra heat without using insolation on concrete without the floor coming up? Its a small area being heated in front of fire place and im using 6 × 48 in tile. Its very costly to run detra heat duo on the entire area when only heating 27 ft out of 515 ft. Any suggestions
Michael
Mann81 is offline   Reply With Quote
Unread 11-25-2020, 09:31 AM   #2
Welcome, Michael.
I can figure out Ditra Heat and insulation, but don't understand the part about the "floor coming up." What flooring do you have that you don't want to remove?
Unread 11-26-2020, 08:59 AM   #3
Tiger Mountain Tile Inc
Welcome to the forum! What I'm confused on is that you want to heat 27 ft only. Is your question "Do I have to install Ditra Heat Duo membrane over the entire concrete floor if I'm only heating 27 sq. ft?"
If that's your question then you have to understand that your heated area will be 5/16 inch higher than the rest of the floor. So, it would make sense to install, at least, Ditra XL over the whole floor which is slightly cheaper than Ditra Heat Duo. Or a 1/4 inch foam backer board. Or self-leveling compound to bring the height up.
James Upton
Tired of bullnose tile trim? Here are 5 edge trim alternatives ~DIYTileGuy
newbie looking for heated floor, SLC advice bigweb2001 Tile Forum/Advice Board 14 07-06-2014 06:39 AM
110 or 220 heated floor Tedshred Tile Forum/Advice Board 12 04-20-2010 04:33 PM
Heated floor ? issbob Tile Forum/Advice Board 2 03-17-2010 04:23 AM
heated floor advice SteveVB Tile Forum/Advice Board 13 12-02-2006 08:36 PM
Sunroom/Flooring/Heated Floor Advice jsnyder262 Tile Forum/Advice Board 10 06-28-2004 07:07 PM
