Unread 09-09-2020, 01:05 PM   #1
Scott12345
Backer Rod for 1/8" movement joint
Hi, I've just finished grouting a 16' by 25' space with Mapei Flexcolor CQ. 12" by 24" tiles over Ditra with 1/8 inch grout lines. Schluter recommends a surface joint to break up spaces over 20'. I did not install a Schluter movement profile but left a grout line mid-field ungrouted and will caulk with Mapesil-T.
I have seen that the caulk is only supposed to make contact with the edges of the tiles and not with the bottom of the grout line. I cannot find backer rod this small at local shops. 3/8" is the smallest available and given that a 1/8" movement joint is the bare minimum I want whatever I use to be flexible as possible and not to be jammed in tight.
Grainger carries several types of 1/8" rubber cord: Buna-N Rubber cord, Neoprene Rubber cord, Silicone Rubber cord, EPDM Rubber cord. Will one of these work? Or is there a source for backer rod that I'm missing?
Thanks! Scott
Scott
Scott12345 is offline   Reply With Quote
Unread 09-09-2020, 02:04 PM   #2
Hi Scott,
I usually don't use backer rod for tile floor joints. I don't know how thick your tiles are or how much thinset is in the bottom of the joint, but I would just caulk it.
Unread 09-09-2020, 02:52 PM   #3
Scott12345
Hi John,
Thanks for the quick reply! It's porcelain about 3/8" thick and the grout line is about 1/2 inch deep.
I was looking at the liberry post on expansion joints which is why I was asking about backer rod. In the post however the author mentions having sealant be at a depth that is equal to half the width of the joint which in my case would end up being 1/16" of silicone. That doesn't seen right... I'll poke around the internet a bit longer to see if can find small backer rod as I only have two tubes of Mapesil T.
Scott
Scott
Unread 09-09-2020, 03:43 PM   #4
Dave Gobis
da Man!
Dave Gobis's Avatar
Been a long time but we used to order a roll of pencil rod, which is 3/16 at the local masonry shop. Never was able to find small amounts.
Unread 09-09-2020, 04:11 PM   #5
Radas
Tile Newbie
Right, wrong, or indifferent, I've used screen spline for 1/8" movement joints under silicone with successful results.
Sent from my Pixel 3 using Tapatalk
Ali
..a new excuse to hoard tools
Unread 09-09-2020, 06:03 PM   #6
Originally Posted by Scott
In the post however the author mentions having sealant be at a depth that is equal to half the width of the joint...
Yeah, Scott, technically this is what the ideal caulked joint should look like:
Commonly a fella just tries to get as close to this as he can.
Ali is going straight to Hell for using screen spline as backer rod! Primarily that's because I never thought of it. If it'll fit in the joint and if your chosen grout won't stick to it, I can't think of any reason it wouldn't work, even being ridged like most of it seems to be. Possible if you're careful you could even get it down into your joint only far enough to approximate a "perfect" bead profile or at least you might get a lot closer than just caulking the joint full.
Unread 09-09-2020, 11:12 PM   #7
Radas
Tile Newbie
Hahaha CX, definitely not my first choice but the only damn thing at Home Depot that was flexible and fit a .12" joint. The stuff I bought was $3 and also had a hollow center with some decent "give" to it. Figured it'd do just fine between Schluter Schiene and hardwood flooring.
Ali
Unread 09-10-2020, 09:03 AM   #8
Scott12345
Thanks everybody! I'll give the screen spline a shot. As the gap is 1/2" deep I figure I can get two or three layers of of screen spline in before the silicone. Or perhaps like CX mentioned just one will have enough friction to hold in place.
I did find an online source for backer rod although the smallest they carry is 1/4". https://www.bestmaterials.com/Backer_Rod.aspx
Scott
Unread 09-10-2020, 01:08 PM   #9
SpaceCadet
Get some sill plate gasket at home depot and cut narrow ribbons of it to fit in the joints. It's about 1/8 in thick.
Paul
SpaceCadet is offline   Reply With Quote
Unread 09-10-2020, 03:34 PM   #10
You want the profile to be round to get the hour glass shape to the caulked joint. Cutting strips from a flat sheet would be flat...not ideal.
Unread 09-11-2020, 07:16 AM   #11
I had zero luck finding small diameter foam backer that didn't come in a 500 foot roll.
The screen spline is genius.
Unread 09-11-2020, 07:58 AM   #12
speed51133
https://www.zoro.com/e-james-rubber-...YaAhHJEALw_wcB
Here is 1/8in neoprene.
Will the 1/4in backer not compress? I have used it in saw cuts in concrete no problem. Those are about 1/8in. Just press it in with a flat screwdriver.
I also found EDPM foam (closed cell) here in 1/8in. That should be a home run: https://www.mscdirect.com/browse/tnp...caAuD-EALw_wcB
Unread 09-11-2020, 09:48 AM   #13
That first link sounds much like Ali's screen spline material, Mike, but maybe even harder. At a Shore A hardness of 70 I don't think it's gonna have much give when putting it in a grout joint. But if the size were right for the application, I can see it working fine.
The second link sounds like exactly what most of us have not been able to find. At thirty-something cents per foot it's a lot more expensive than the hard stuff in the first link, but would certainly be easier to get into joints that were a bit tight.
Good information.
Unread 09-11-2020, 10:06 AM   #14
speed51133
https://www.mcmaster.com/epdm-cords/...dm-foam-cords/
half the price
Floor Movement Joint Caulk jmtrup Tile Forum/Advice Board 1 02-13-2013 01:14 PM
Perimeter movement joint carroscott314 Tile Forum/Advice Board 1 09-16-2011 12:28 PM
movement joint maynards Tile Forum/Advice Board 21 09-16-2008 10:55 AM
Movement joint question L.R.Puckett Jr. Professionals' Hangout 4 10-09-2006 08:25 PM
expansion/movement joint confusion John Tile Forum/Advice Board 28 06-05-2002 05:07 PM
