Old 09-22-2018, 09:15 AM   #1
Northmen
Silicone Before or After Grout ?
Seems like most people like to grout first. I'm thinking the grout would be easier to clean off the newly applied silicone than the other way around.
Either way I find applying 100% silicone more difficult than standard water based caulk.
Does anyone like using the plastic caulk tooling kits?
Lastly I noticed the 100% silicone will shell over and become difficult to spread in the joint. I tried spraying water but that made it worse.
Steve
Northmen is offline   Reply With Quote
Old 09-22-2018, 09:26 AM   #2
Hi Steve. When using caulk, I like using water to smooth it out. For silicone, I use Acetone.
To me, it's easier to grout first. While washing, use a tool to rake the grout out of the joints you want caulked. Let the grout dry, then caulk.
But, there are no rules, you can do it either way.
Old 09-22-2018, 09:38 AM   #3
Northmen
Thanks Davy. I've also seen people that won't tool in there beads but they end up with pin holes and it doesn't look good.I use nitrile gloves and my index finger for tooling.
I'll try the acetone on a master shower I'm finishing up.
Steve
Old 09-22-2018, 09:42 AM   #4
Yeah, I use my fingernail to smooth out the caulk. Turn your hand so your nail is against the caulk, then slide it up the corner.
Silicone isn't water soluble so water doesn't work with it.
Old 09-22-2018, 01:02 PM   #5
rmckee84
rmckee84's Avatar
I like using denautured alcohol. Run the bead, spritz will alcohol, then tool. I use an old credit card, or one of the laminate countertop sample chips that they have at Lowe's and hd.
Ryan McKee
Old 09-22-2018, 01:19 PM   #6
Silicone tutorial
Old 09-22-2018, 06:04 PM   #7
Karls tile Inc
For silicone get a spray bottle and put some Dawn in it with water. Get a caulking dressing tool. Install the silicone and then spritz it with the soapy water solution. Dress the caulking with the tool and wipe off the excess of the tool with paper towels. Super easy!
Karl
Karlstile.com
Old 09-22-2018, 06:31 PM   #8
Learn something every day, thanks Karl.
Old 09-22-2018, 06:54 PM   #9
Da Home Builder
Steve, the tile industry standards call for grouting before applying flexible sealants.
You can, of course, do it in whatever order you like, but I'd recommend you grout and let that cure at least 24 hours before any caulking.
Old 09-23-2018, 02:52 AM   #10
Karls tile Inc
No problem Davy I learned that trick from the NTCA seminars that come through every year.
Karl
Karlstile.com
Tec Skillset Silicone Caulk vs Tec Accucolor Silicone Sealant adellecave Tile Forum/Advice Board 3 12-24-2016 06:38 AM
How to remove silicone based sealer so i can use silicone caulk in shower lccavender Tile Forum/Advice Board 7 10-29-2015 05:19 PM
Silicone Grout Sealer Darkened Grout - How to Remove mark144 Cleaning, Restoration and Sealing 4 10-11-2015 11:10 PM
Grout or Silicone? Gordy Tile Forum/Advice Board 7 05-07-2008 03:49 PM
Silicone instead of Grout? Muddy Waters Tile Forum/Advice Board 6 11-14-2007 02:38 PM
