Unread 05-08-2011, 07:03 AM   #1
Davestone
Florida Tile & Stone Man
Ridgid 7" wet saw model 4020
Okay,i needed a small saw for those small jobs i don't wanna drag the hundred pounder to.Sold my little Felker like a dummy back when all i did was monster jobs.So after researching i bought the table top version at HD $189.00.I didn't want the large versions with stands and tray.
I am not impressed.First off it was missing the two screws for the shroud.Second, the 45 attachment is made so it rubs against the splash hood for small cuts,unless you raise the hood and get wet.It is also hard to see what you're cutting,but the see through hood helps.Not much splash,it is directed right at the right side of your clean shirt.The on off switch is also a little awkward.
......On the plus side....
The saw is heavy,so it doesn't move around,and the blade seems good for the porcelain i'm cutting,and the power seems adequate..It has a large table so it handles larger tiles.It will do,and was less than $200.00 http://www.homedepot.com/Flooring-Fl...atalogId=10053
http://Davestonestile.com
Ridgid 4007 wet saw. Jayme568 Professionals' Hangout 9 03-13-2011 04:19 PM
Ridgid wet saw Davestone Professionals' Hangout 184 06-23-2009 07:17 PM
Ridgid Wet Saw 1Year Review evan1968 Professionals' Hangout 19 04-27-2009 08:07 AM
Ridgid wet saw tilemaker Professionals' Hangout 1 10-12-2007 07:10 AM
I need achieve a "Wet look" on 24" Slate. Hamilton Cleaning, Restoration and Sealing 4 11-13-2005 08:09 PM
