Unread 11-28-2010, 09:51 PM   #1
ncstevem
First tile project - need advice
I have an extremely small bath (6 x 6 - 'L' shaped not including the shower) which is gutted to the studs and joists.
The original shower pan had 1 x 6 's under it which I left in place so I used 3/4" plywood on the rest of the floor to make everything level. I screwed the plywood to the joists. Is that a problem for a bath this small? I've read elsewhere that you shouldn't screw the plywood to the joists while others have disputed that opinion.
I planned on using 1/4 ' plywood under the new shower pan and over the original 1 x 6 's as well as 1/4" cement board over the 3/4" plywood. Should I have used 1/2" plywood (instead of the 3/4) and 1/2" cement board instead? Don't think I can use 1/2" cement board with 3/4" plywood because I won't be able to fit the tile under the existing bath door marble threshold which I want to keep.
Thanks for your help.
Steve
ncstevem is offline   Reply With Quote
Unread 11-28-2010, 10:17 PM   #2
Dave Taylor
Dave Taylor's Avatar
Hello Steve........
and welcome to Tile Your World forums.
You write
1. How did placing 3/4" plywood "on the rest of the floor" make it level to where the 1 x 6 's were left in place and not covered with 3/4" plywood?
2. I would not consider using 1/4" plywood as an underlayment anywhere in this bath.
3. 1/4" is the manufacturer recommended thickness for CBU used as flooring undelayment...... unless extra thickness is needed for height matching.
Dave T (DIY'er)
the net.
Unread 11-28-2010, 10:55 PM   #3
Jalisco
F+V Tile
Thumbs up hello steve
Iam not so sure about what are you trying to explain but as far as laying tile over 1/4 ply is a no no at least 3/4 and 1 1/4 for setting marble and plywood is ok to screw it to the joist and but try to avoid to do it on the backer board and use screws that not go over your thickness of plywood and backer board example 3/4ply +1/2 BB use max 1 1/4 screws hope this help u keep me informed and good luck:
Eric
Jalisco is offline   Reply With Quote
Unread 11-28-2010, 11:10 PM   #4
Dave Taylor
Howdy Eric.........
Please slip on over to our TYW "Professionals's Hangout" forum and tell us a bit about yerself' amd yer' NC tile experience and bidness'.
And...... like Eric says Steve..... don't plan on using any 1/4" ply underlayment beneath a ceramic tile covering,
Dave T (DIY'er)
the net.
Unread 11-29-2010, 04:57 AM   #5
ncstevem
The 1/4 plywood...
will only be under the (1 piece - transolid) shower pan. So the pan would be sitting on top of 1/4" plywood plus the 1 x 6's.
The rest of the bath floor where the tile would be installed would have 3/4" plywood and 1/4" cement board. I was asking if it would be better to use 1/2" plywood with 1/2 " cement board for the tile subfloor instead of the 3/4" with 1/4" configuration or does it really matter.
Sorry for the confusion.
Steve
Unread 11-29-2010, 07:52 AM   #6
Welcome, Steve.
If I understand what you're doing, it matters a great deal.
You have removed the original board subflooring in the rest of the bathroom, outside the shower area, is that correct?
If so, you absolutely don't want to start with half-inch plywood for your subfloor. If your joist spacing is 16"oc, starting with 3/4" plywood would be a minimal subfloor for a tile installation, but adequate for some substrate manufacturers.
There is never an advantage to using thicker CBU for you substrate unless you need the additional height. None of them add anything structural to your subfloor.
Have you evaluated your joist structure to determine the suitability for a tile installation?
I would not want any quarter-inch plywood even under a pre-fab shower receptor.
Bathroom tile project advice... capybaras Tile Forum/Advice Board 6 11-28-2009 10:35 PM
Need Advice on Slab Prep and Tile Project TexasTiler Tile Forum/Advice Board 2 12-18-2008 06:02 AM
Need advice on basement tile project - please anjoutwest Tile Forum/Advice Board 11 11-07-2008 06:55 PM
Needs advice and wisdom for basement tile project A847467 Tile Forum/Advice Board 2 01-05-2008 09:19 PM
Newbie needs advice on big tile project IdahoDave Tile Forum/Advice Board 1 06-02-2004 01:39 PM
