Unread 09-15-2010, 01:17 AM   #1
Plumb Crazy Purple
finishing tub edge
Hi Guys,
I need some advice/ideas on how to finish the edge of the tub. There's a gap between the tub edge and wall. I'll be installing a shower head and want to prevent the water from spraying out the sides. The gap varies from 1/4 to 1/2. I was planning on using polyurethane adhesive to glue some 1/4 round pieces to bridge the gap. Attachment 82838Name:  tub 003.jpg
Plumb Crazy Purple is offline   Reply With Quote
Unread 09-15-2010, 07:04 AM   #2
Edthedawg
Edthedawg's Avatar
Hi Peter,
Please add that first name to your signature, so we continue to know who you are (UserCP in the dark blue band, upper left corner of the screen)
What you've got there is, well, highly unusual. Nothing we can suggest is gonna be remotely adequate. That tub's gonna move around a LOT as it warms up and cools down, which is gonna play havoc with whatever you try to do to bridge off the wall onto that wide deck. Polyurethane would be a real problem if it's bonding both the tub and the walls - that'll crack in a heartbeat. You need a lot more flexibility if you actually go thru with this plan.
Does that deck slope uniformly, all around, IN towards the tub? Or do some areas kinda slope down / away / out of the tub?
Did you just build those subway walls? If so, what're the construction details? What's the waterproofing employed?
If they're old walls, and they likely have no waterproofing in them, then what's your plan to keep this from all A) leaking a lot of water down the sides, and/or B) simply falling apart, and right quick?
Were you planning on cracking open a few rows of tile on the walls, and tying in some kind of membrane, and building yourself some kinda stubby shelf to overhang the walls onto that fat tub deck?
Have you considered just putting a simple shower curtain surround up, like a "normal" clawfoot tub/shower gets?
Ed
GO SOX!
Unread 09-15-2010, 09:49 AM   #3
If not, please do so. What you are planning is not likely to work and will be a maintenance nightmare.
Unread 09-15-2010, 07:11 PM   #4
Plumb Crazy Purple
I installed the subway tile on top of cbu and felt. All the walls are insulated. I used epoxy grout.
The deck is not uniform. It has a slight slope towards the tub. But the deck has a bit of a hump in the center where it slopes towards the drain side and the other end of the tub.
My thoughts were to use the polyurethane adhesive to glue the top edge of the 1/4 round to the subway. I've used PL polyurethane adhesive before on other things and it stayed flexible. It was not like liquid nails. I would use spacers and tape to keep a gap at the tub deck. Then I would seal the gap between the tub deck and bottom of the 1/4 round with silicone. I would also seal the top of the 1/4 round with silicone. I also thought about using some solid copper wire and gluing that to the back side of the 1/4 round to help hold the row in place. I figured the polyurethane was a better stronger bond than silicone.
I do have a shower curtain ring, but wanted to take advantage of the tub deck. I wanted to get the single curved shower rod that spans from opposite walls. I've seen these in hotels and it makes me feel less confined because the rod curves outward and holds the curtain further away.
Your thoughts?
Peter
Unread 09-15-2010, 07:33 PM   #5
Shawn Prentice
Same thoughts as Ed and Bob. That tub is not suited for that area unless you use a typical claw foot tub curtain.
Add: you do realize those trim tiles you want to use will just create a water trap against the wall, right?
Shawn Prentice is offline   Reply With Quote
Unread 09-15-2010, 07:40 PM   #6
Topspin
SchluterUgrad
Topspin's Avatar
Same as others - your plan says "crack" to my thinking. Tub looks nice just where it is. Floor tile and claw foot says keep in same era and use a claw foot tub curtain. Really looks nice there though.
Unread 09-15-2010, 07:54 PM   #7
mynewshower
Tile Contractor, California
If still do not want a curtain...
If you are still not sold on a shower curtain, the advice that I would give would be a Plastic, 1" quarter round. I would apply this with 100% silicone adhered to the shower wall and also to the tub deck. The type of tub that you have was not meant to be tiled in, and there is really no perfect fix.
Matt
Walk In Baths and Showers
mynewshower is offline   Reply With Quote
Unread 09-16-2010, 01:10 AM   #8
Plumb Crazy Purple
Can you explain "water trap"? I guess I could have another shower curtain ring made into a "D" shape to achieve that curve. If I can't stand it, that 1/4 round plastic sounds better than the trim tiles. Thanks for all the advice.
Peter
Unread 09-16-2010, 01:24 AM   #9
He's talking about how water will "pool" up against the trim tile if the tub's shoulder isn't sloping towards the inside of the tub.
Finishing a tub surround edge with river rock Greengurl Tile Forum/Advice Board 3 02-05-2009 12:06 AM
Finishing to a curved edge. EasyPete Tile Forum/Advice Board 5 11-05-2005 01:42 PM
finishing tile edge adrian Tile Forum/Advice Board 13 05-21-2004 05:58 PM
finishing edge of balcony skydivehasher Tile Forum/Advice Board 25 01-16-2004 09:51 PM
Edge finishing on granite tile Frank Tile Forum/Advice Board 15 08-07-2002 06:49 PM
