Unread 02-06-2020, 04:52 PM   #1
ELF3
Advice on Underlayment and matching 3/4” hardwoods
Hello all,
I’d like to ask for your help on choosing the appropriate product to go under my tile. Let me know if I’m missing any necessary specs:
2x8 joists with bands underneath, 16” OC in this area. Joists are running 7’ between the girders/piers. I have actual 3/4” AdvanTech glued and nailed down.
I’m using a roughly 3/8” thick mosaic tile, so Ditra or Ditra XL is out. I’m afraid 1/2” CBU would put me higher than the neighboring 3/4” to be installed hardwoods, but wasn’t sure if 1/4” CBU would be enough support. What do you recommend go over the Advantech to try and mate these surfaces cleanly? It’s a 5x5 bathroom, so cost isn’t a huge issue. Ive attempted to search and not not ask repetitive questions and I’ve read about (green skin, noble, or MAPEI) but those would almost be too low without something additional. Thanks in advance, you all are a wealth of knowledge.
Ernest
ELF3 is offline   Reply With Quote
Unread 02-06-2020, 04:54 PM   #2
jlbos83
Really Cool Weekend Warrior
Those more expert than I will come along, but 1/4" CBU is fine on the floor, recommended, even.
Jeff
It's a DRY heat!
jlbos83 is offline   Reply With Quote
Unread 02-07-2020, 06:57 AM   #3
ELF3
Thanks Jeff. I checked HardieBacker’s site and they agreed. Just looking at the stuff in store, it appears flimsy.
Ernest
Unread 02-07-2020, 04:07 PM   #4
Had you checked DitraXL? It was designed specifically to address your issue, but that also assumes your tile is compatible (at least 2x2").
Wedi approves the use of their panels on a floor. Those come in various thicknesses, generally in 1MM increments that might work for you.
Schluter had been testing their KerdiBoard panels to be used in the same manner, but I never heard back from them on the result of their testing...you could give them a call to see if that might work for you.
Unread 02-07-2020, 04:29 PM   #5
jlbos83
Hardi is flimsy! Its job is not to provide structure, it's to provide a good surface for laying tile. If our Advantech is layed properly, 1/4" Hardi (or any other 1/4" CBU) could be just what you need, assuming the tile is not natural stone.
Jeff
It's a DRY heat!
Unread 02-09-2020, 01:48 PM   #6
ELF3
Jim,
Yes, I’m planning on mosaic tile in this particular room. I believe I will try Ditra XL on the other two rooms as the 175 sq. ft. roll would be about right and I’d like to try it out. When you consider putting a waterproof membrane on top of the CBU, Ditra doesn’t sound nearly as expensive. Thanks all!
Ernest
Unread 02-09-2020, 02:06 PM   #7
Tiger Mountain Tile Inc
I think you'll need a 1/4 inch backer board and from there I would check the height. With the 1/4 inch and thinset underneath it you might be close enough. Remember to have a small gap between the hardwood and tile. At that point, if you're within 1/16th to the height of the hardwood you'll probably be OK.
You could also add a layer of 1/8 inch Wedi board on top which would give you a waterproof layer but their board is 1/8"+. Also, it needs to be thinset down.
So you might try to purchase some Ardex Feather Finish or Mapei Planipatch and just feather the entrance of the room a little bit higher. You can do this on top of the cement board.
Jim Upton
DIYTileGuy
Advice on Matching Newly Installed Tile with Old ryansims Tile Forum/Advice Board 8 03-25-2016 03:44 PM
Matching previous tile and underlayment melduforx Tile Forum/Advice Board 2 05-26-2015 09:27 PM
Advice on tile and/or matching subfloor? YW84U Tile Forum/Advice Board 3 02-24-2015 10:29 AM
Advice on matching color of existing grout fineline Professionals' Hangout 3 02-02-2010 10:09 PM
Hardwoods onto gypcrete? bwlee Professionals' Hangout 18 10-03-2002 08:38 PM
