Unread 08-13-2019, 08:12 AM   #1
Chisos
Floor joist and deflection rating
Hello,
We are having a bathroom added to the house. The perimeter foundation is a poured concrete base with 2 rows of concrete blocks. The joists are 2x8 pine, 16oc, 10 span. Does it change the deflection rating if those joists are attached using joist hangers to attach to stringers that have been attached to blocks?
I plan to put down porcelain tile over ditra xl as in the rest of the house.
Thank you so much for your help!!
Melody
Melody
Chisos is offline   Reply With Quote
Unread 08-13-2019, 08:15 AM   #2
HooKooDoo Ku
How the joist are attached make little difference compared to the other prime factors of wood species, joist cross section, spacing, and span.
Joseph
Unread 08-13-2019, 08:24 AM   #3
Welcome back, Melody.
This the same house you were working on last year?
The floor joist attachment to a rim joist using metal hangers is a sound building method. The attachment of the rim joist, if not set atop the foundation wall, is usually the weak link.
Unread 08-13-2019, 08:48 AM   #4
Chisos
Thank you so much!
Yes, this is the same house - we will probably be working on it until I die or it kills me.
I was unsure of the joist hangers affect on d-rating so I had them change to 12" oc. That gives me much more wiggle room on deflection rating anyway - which I like. I wanted to get that changed before they began attaching things. The guys seem to be in a much better mood when I make changes to their plan BEFORE they execute them.
Melody
Unread 08-13-2019, 10:22 AM   #5
Trask
Oregon Tile Man
Trask's Avatar
Hey Melody
12”O.C makes me giggle ... I like that sort of insurance under foot . Reducing
Joist spacing is under rated ( I believe) ...it does a lot to reduce point load deflection and I’ve suspected many of the engineered I-joist systems have not helped us in this regard with odd allowances I’ve seen at 19.2” or 24” 0c .
Trask Bergerson
Bergerson Tile and Stone
Astoria, Oregon
Unread 08-13-2019, 10:42 AM   #6
speed51133
my house has engineered trusses with like 20in spacing.
The hvac guy cut through many strongbacks to run the venting....
The floor was like a trampoline until I repaired them. Too bad your deflecto does not figure trusses into the calcs.
Unread 08-14-2019, 05:35 AM   #7
Chisos
Thank you all for the replies.
My GC dropped by in the afternoon to check on the job and was trying to tell me it was a bit excessive to go 12oc. Told him I'm doing the tiling, I'm old, I only have one more tile job left in me and I want it perfect. I can do my part perfectly but need his part to be perfect.
Later I went out to check and found them nailing the Advantix to joists - no, no, no boys. I want it screwed every 8". Sad faces but they did it.
At this point, to his credit, my GC tells the guys to "just do what she says". Makes me smile!
Melody
How to Beef up Deflection Rating posulli Tile Forum/Advice Board 2 03-09-2016 10:12 AM
Deflection rating for engineered joists sdelphy Tile Forum/Advice Board 7 10-08-2015 03:41 PM
Help with I-beam Deflection Rating Sloblond Tile Forum/Advice Board 9 06-27-2014 11:03 PM
Need some with deflection rating Hunter Tile Tile Forum/Advice Board 5 01-08-2012 08:04 PM
reinforced floor joist deflection Kevmitsu Tile Forum/Advice Board 29 08-10-2009 05:30 AM
