Unread 12-27-2018, 11:05 AM   #1
NowhereMan
subway trim tile around window
I did a pebble tile shower several years ago (which is still going strong), and this forum was a fantastic reference back then. Now, I'm working on a subway tile backsplash. The original plan was just to go up 12" to the bottom of the windows. That's done (except for grouting/caulking), and it went so well that the wife decided we should have it go all the way up to the ceiling. I'm OK with that, but I'm not sure what to do around the windows. Something easy that does not look to amateurish would be ideal...
Btw, the tile I'm using is 2" x 4" and it's only white on the surface, with the inside being grayish. As far as I know, there are no matching bullnose pieces or anything like that.
Mark
NowhereMan is offline   Reply With Quote
Unread 12-27-2018, 11:09 AM   #2
NowhereMan
Forgot the picture...
Mark
Unread 12-27-2018, 12:12 PM   #3
rmckee84
rmckee84's Avatar
There's several options, some cost more than others and some just take more time.
-get some solid surface (quartz, marble, granite, corian) and put it up for jambs around the window and use pieces wide enough to cap the tile running up to it
-mitre the outside corners and run the tile up the Jamba
-use profiles to cap the cut edges of the tile
There's others too but those are the most common
Ryan McKee
Unread 12-27-2018, 02:42 PM   #4
NowhereMan
Thanks for the quick reply! Granite, quartz, etc., is too much for this kitchen, as it's a pretty basic setup. And mitering is not a realistic option with my equipment. I'm not a big fan of those profiles that cover up the ends.
How about something like maybe a quarter round wood trim around the windows, with a grout joint between that and the end of the tile? Or maybe even just leave it "raw" but paint it? Too cheesy?
Mark
Unread 12-27-2018, 02:55 PM   #5
If you do the wood trim, Mark, you want to use a color-matched caulk between it and your tile.
Unread 12-27-2018, 03:03 PM   #6
IMO, Mark, a small quarter round will look way out of proportion.
If there are no matching trim/finish pieces available, and you're trying to do this inexpensively, I'd be inclined to add a 1X flat casing around the window, and just have the tile die against it.
Unread 12-27-2018, 03:10 PM   #7
NowhereMan
Yes, 1" flat trim seems like it might be the way to go. The wife wants black grout, so I'm assuming it would be black caulk between the trim and the end of the tile?
Mark
Unread 12-27-2018, 03:28 PM   #8
Yup.
Given the black caulk, I'd keep the joint between the tile and the 1X pretty darn tight to avoid a wide bead, I'd also run some painters tape down the edge where the tile abuts the 1X before running the caulk. It'll be a bit of a challenge to keep it all looking tidy.
Unread 12-27-2018, 04:11 PM   #9
Raymond S
Carpenter - Tile Setter
Why not just trim out the window and butt the tile into the casing? Leaving a caulk joint, as mentioned.
Raymond
Raymond S is offline   Reply With Quote
Unread 12-27-2018, 05:25 PM   #10
What size joints do you have? I would make a sample board and experiment with the grout. We've had several threads lately with dark grout looking splotchy. And, remember that dark grout shows every imperfection in the tiles.
Unread 12-27-2018, 06:44 PM   #11
NowhereMan
Ha ha! Yes, I've done some research and I know about the dark grout showing all imperfections (and, yes, I have been known to have a few imperfections...). I've explained all of this to the wife, and she still insists on the dark grout.
One more question...Instead of butting the tile against the trim, how about "backband" moulding, that is, moulding that fits over the top of the tile edge? It seems like that would likely give a lot cleaner look.
Mark
Unread 12-27-2018, 07:02 PM   #12
workhurts
I used white metal Schluter trim for mine. In fact I ripped out the old trim and replaced with the Schluter trim for a cleaner look. I also resized the window slightly with something like lauan to get full tiles instead of slivers.
Charlie
Unread 12-28-2018, 08:03 AM   #13
rmckee84
rmckee84's Avatar
I've ripped the backside of trim and let it go over the tile, that works just fine if you want to go that route.
Ryan McKee
Unread 01-01-2019, 01:05 PM   #14
NowhereMan
Thanks for the advice so far.
Another question... What type and brand of grout would you recommend? Sanded, unsanded, cementitious, epoxy, other?
I've done 2 pebble tile bathrooms and used spectralock epoxy grout (lots and lots and lots of epoxy grout--see the attached picture) on both of those, and that's held up really well. So, I'm tempted to use it again. I suppose it's overkill, but that's all that I know...
Mark
Unread 01-01-2019, 05:51 PM   #15
rmckee84
rmckee84's Avatar
For a backsplash I'd go with PCS if you like Laticrete products. Spectralock would be overkill but there's no reason you couldnt use it.
Ryan McKee
Caulking tops of door trim and window trim? netrate Tile Forum/Advice Board 4 07-09-2016 01:22 PM
Kitchen Subway Under Window Trim? Dave Anderson Tile Forum/Advice Board 17 02-24-2014 10:32 PM
Tiling around window and door trim--raise the trim? bek Tile Forum/Advice Board 11 07-19-2008 02:37 PM
Need advise on tile trim window DumbCop Tile Forum/Advice Board 12 03-14-2005 09:47 PM
Design help w/subway trim tile for a newbie hwolfson Tile Forum/Advice Board 16 01-23-2005 07:19 PM
