Unread 09-10-2012, 12:20 PM   #1
Franko
"Chicago Electric" tile saw ??
I see an add for a used 10" Chicago Electric tile saw, 2.5 h.p. with PVO tray and stand, single phase, 3340 rpm. $200.
Is this a good brand? I hadn't heard of it before. Anyone have a recommendation?
Frank
Franko is offline   Reply With Quote
Unread 09-10-2012, 12:43 PM   #2
HooKooDoo Ku
Is this what you're looking at (only $250 brand new).
Do a little Googling on "Chicago Electric" and "Harbor Freight" to get an idea of quality.
I personally wouldn't buy anything like that unless it was 50% off or more from current retail. IMHO, it's better to buy brand new - that way you know the history of the tool, and if there is a problem with it right out of the box, you can return it without any hassles.
Joseph
Unread 09-10-2012, 01:15 PM   #3
pwgsx
pwgsx's Avatar
Mine looks like the older version of that, its blue, has a grey water tub, with the sliding shelf.........I used that same one with no issues but the water pump going out BUT it cut just fine. I also then cut bricks with it building a outside kitchen area. Still running strong. No issues
Phillip
pwgsx is offline   Reply With Quote
Unread 09-10-2012, 02:03 PM   #4
Franko
Ouch -- I didn't realize Chicago Electric was related to Harbor tools. Enough said. Thanks for making that connection for me.
Frank
Unread 09-10-2012, 04:41 PM   #5
Lazarus
Lazarus's Avatar
Yeah, actually my partner bought one a couple of years ago and it's still running strong. Make no mistake, it isn't a Target or a Felker...but it still works and still cuts straight......For $200 bucks, pretty hard to beat.
Laz...
Unread 09-10-2012, 05:12 PM   #6
My dad bought one but it was an older model. Like Laz said, it's not a top of the line saw but it wasn't bad for what he paid for it.
Unread 09-10-2012, 06:30 PM   #7
prostuff1
I recently picked up the 7in bridge saw version. I have been using it for about the last week and i really do like it. For what i paid for it it is completely worth the money. Also try this coupon for some extra money off.
I was borrowing a cheaper saw from a friend but was not impressed (his was a portable table top saw that was extremely cheap). For a little bit more i grabbed the bridge saw from harbor freight and could not be happier. I have been impressed with the cuts and am planning to use the saw for the bathroom project next year and the first floor reno that will likely happen the year after that.
Kyle
prostuff1 is offline   Reply With Quote
Unread 09-11-2012, 06:51 AM   #8
pwgsx
pwgsx's Avatar
Yea if you dont plan to do tile for a living and this is weekend project I would buy it. H.F. will also return used items if they dont work or you were not happy with it.
Phillip
Unread 09-11-2012, 02:50 PM   #9
Franko
I just re-read the Tile Saw Appendix in "Tile Your World." I am planning to do a project with 18" tiles, and had planned to lay them diagonally, which means my cuts would be 25 and 1/2" long. To get that long of a cut, i would need a really big tile saw -- a lot bigger than most of the ones in the under $300 market that I've seen.
If you're going to cut 18" tiles diagonally, is buying a really big tile saw your only option? I assume you can't reliably cut diagonals on a manual tile cutter?
What do you guys do in this situation??
Frank
Unread 09-11-2012, 02:58 PM   #10
Lazarus
Lazarus's Avatar
A "Bridge Saw," mentioned above should do it for you.
Laz...
Unread 09-11-2012, 06:22 PM   #11
prostuff1
With the bridge saw I linked above I could, if I had to, get a 26in long tile in there. A masonry block would have to be a little bit shorter because of the added thickness.
Kyle
Unread 09-13-2012, 03:01 PM   #12
Franko
Can you snap tile diagonally with a manual tile cutter?
Frank
Unread 09-13-2012, 03:30 PM   #13
Lazarus
Lazarus's Avatar
With a GOOD quality unit and with SOME tile....yes, you can. "Reliably" and "Every Time?" Unlikely...............a wet saw is preferred.
Laz...
Chicago Electric 10" tile saw from Harbor Freight dustin999 Tile Forum/Advice Board 88 01-26-2014 11:08 AM
Using Chicago 10" Tile Saw rambo1224 Tile Forum/Advice Board 3 04-19-2010 09:34 AM
10 x 10 tile, "made in USA" & "BWP" pitterpat Professionals' Hangout 2 10-14-2006 04:41 AM
Tile Advice - "Pops" and "Snaps" Coming From Under Tile Hokiedale Tile Forum/Advice Board 5 08-29-2006 07:35 PM
Joists marked "SPI-Quincy" "Hem Fir"? echap Tile Forum/Advice Board 10 04-16-2006 07:13 PM
