Unread 01-14-2020, 11:12 AM   #1
dizzy2908
Archway finishing advice!!
Hello,
I am a DIYer with some tiling experience. Regarding tiling outside corners, I have done bullnose and mitered cuts. However, I have been asked to help with a project to tile a kitchen with subway tiles. There is an archway pass through. The archway will not be tiled, so my question is how to finish where the tile meets the archway. I will obviously have to cut the radius in the tile so that would negate any bullnose finishing and since the archway isn't being tiled, that would eliminate mitered joints as well. Any advice on how to finish subway tiles along an archway curve would be very helpful. I've attached an image. The white wall will be tiled, the archway that is orange will not be tiled.
dizzy2908 is offline   Reply With Quote
Unread 01-14-2020, 11:20 AM   #2
Welcome, Dan.
It's possible to put a suitable edge on thru-body porcelain tiles or stone tile, but even that will be difficult with your curved edges.
I think you're probably limited to finding an edge profile material that is flexible enough to go around the arch and cover the tile edges.
I know Schluter makes a wide selection of profiles, some of which are somewhat flexible, but I don't recall the names of the ones that are bendable. Perhaps someone else will or perhaps you can find a selection online.
Unread 01-14-2020, 11:32 AM   #3
dizzy2908
Thank you! That's what i figured I would have to do. Thank you for confirming. I believe they are going with ceramic tile which would not give a nice edge unlike the porcelain and stone. But you are right, even with those materials it would be extremely difficult to get a smooth clean edge (for someone who doesn't do this all the time anyway). I will definitely look into the Schluter products.
Unread 01-14-2020, 01:18 PM   #4
HooKooDoo Ku
What size tile are you using?
That archway seems to be 6' to 8' wide, and doesn't have a very tight radius. If you're using 4" to 6" tile, I think approximating the archway with strait cuts on the tile will be good enough.
Joseph
Unread 01-14-2020, 01:35 PM   #5
dizzy2908
Joseph,
Thanks for the reply! I am not so much worried about cutting the radius. What is concerning me more is after I cut the ceramic tile, it will have an unfinished edge that isn't glazed and/or will not be visually appealing, unlike if it was on a straight corner where I could use a bullnose tile. But you are right, that the straight cuts would be cleaner than curved cuts.
Unread 01-14-2020, 11:36 PM   #6
Using whole tiles stood on end (sailor style) would look cool with a keystone in the center. That way all your cuts would be in the field, at the top of the whole tiles
Unread 01-14-2020, 11:40 PM   #7
Or use a bullnose along the bottom edge....
Unread 01-15-2020, 06:39 AM   #8
That's what I would do. Pie shape pieces of bullnose and cut the field tiles into it.
Unread 01-15-2020, 02:58 PM   #9
dizzy2908
Thank you all for the replies! It looks like I definitely have some options. I was thinking about doing the pie shapes, but didn't know how it would look since I am not tiling the inner part of the arch (e.i. would there be little overhangs visible from the other side).
Unread 01-15-2020, 03:26 PM   #10
No, Dan, you could let those wedges die at the wall/arch junction with nothing at all visible from the opposite side. A little tedious, perhaps, but doable.
Unread 01-15-2020, 07:51 PM   #11
And we forgot to mention --- you're about to find out how uneven that arch really is.
The arch in the pictures I posted were self made, exact copies of each other. (copied from the library on the first floor)
Archway- Need Advice or Help Please jkull Tile Forum/Advice Board 26 10-06-2017 04:47 AM
need advice on finishing my tile project rookietjx2 Tile Forum/Advice Board 17 12-18-2014 11:33 AM
Advice on finishing off this tiled edge? Shane72 Tile Forum/Advice Board 2 12-17-2014 10:48 AM
advice finishing corner between new tub and non-tiled wall skiadct Tile Forum/Advice Board 1 07-10-2006 09:16 PM
Advice on waterproofing and finishing a large fountain Kenr Tile Forum/Advice Board 5 01-16-2006 08:58 PM
