Unread 12-17-2018, 10:07 PM   #1
Raymond S
Carpenter - Tile Setter
Cutting glass mosaic
Does anyone have any ideas or tips on how to cut this mosaic without chipping?
Glass rhomboids alternating with a porcelain with a glass-type glaze, glass blade won’t cut through the porcelain very well and the regular blade chips out the glass. Name:  C9CA1B09-5BE3-4A06-B866-05E67E279AF6.jpg
Raymond
Raymond S is offline   Reply With Quote
Unread 12-18-2018, 08:42 PM   #2
You may have to switch blades for each material. I've never had much luck with a standard blade on glass, for the same reasons.
The only other suggestion I can give would be to raise the blade until the edge is just below the bottom of the glass. This may reduce chipping. You might also try scoring the top, maybe halfway through the thickness of the glass, then flip it and cut the backside.
Unread 12-19-2018, 02:08 AM   #3
Raymond S
All good ideas, thank you. Will try them all.
Raymond
Unread 12-19-2018, 07:16 AM   #4
Lou_MA
Even with a good glass blade, I’ve always had a tough time getting clean cuts on those tiles with granules. The edge seems to want to crumble. I haven’t found any method to avoid that.
Lou
Unread 12-19-2018, 07:21 AM   #5
thuffner3
the tiles with glass granules are a pain,
use super glue and coat your cut line it helps tremendously.
Neil Jackson, from Cincinnati, Ohio
Her contractor said she could have it installed today.
thuffner3 is offline   Reply With Quote
Unread 12-19-2018, 02:06 PM   #6
Does a smooth rim verses segmented one make a difference?
Unread 12-19-2018, 04:42 PM   #7
Raymond S
Have been using a continuous rim blade. Glass blade won’t cut the porcelain and porcelain blade chips the glass tiles and the glass glaze on the porcelain.
I appreciate yalls input on this, good tips all.
Raymond
Unread 12-19-2018, 07:02 PM   #8
Montolit CPV 250 glass blade, the most amazing blade I’ve used. It cuts glass and sensitive ceramic glazed tiles the best I’ve seen. Paul reccomended it to me on the forum and I’m hooked
Unread 12-19-2018, 08:06 PM   #9
Raymond S
Thank you Justin for the blade recommendation. We will get this thing done, thanks to you guys.
Raymond
Cutting Glass Mosaic Tile Lengthwise rwbil Tile Forum/Advice Board 19 09-30-2016 07:23 AM
Cheap Upgrade for cutting Glass Mosaic Tile Charimon Professionals' Hangout 8 05-22-2012 07:04 AM
Cutting Glass Mosaic Tiles uofmrocky Tile Forum/Advice Board 6 04-14-2009 04:53 PM
Cutting Glass&Slate Mosaic Tiles youngblood Tile Forum/Advice Board 6 02-16-2009 09:09 AM
Tile Saw for cutting 1" glass mosaic lko Tile Forum/Advice Board 19 08-09-2006 05:30 AM
