Unread 11-18-2020, 05:47 PM   #1
espo21
Trying to tile a backsplash on a wavy wall
Hi everyone, I'm trying to tile a backsplash on a wall that's pretty wavy, with gaps in the 1/4' - 3/8" range over a 6' span. I've spent quite a bit of time researching previous posts as this question seems to come up quite a bit. Seems like the general response is to build up the low spots with hot mud and screed it up using a straight edge. Prime then tile. So this was my plan. (I'd love to rip it all out and add durock but the wife shot that idea down quick
I reached out to USG to see what product they would recommend for doing this, and their response was a resounding NONE. They said no product of theirs is designed to take on the weight of tile when applied at that thickness.
So now I'm stuck.. I'm looking to go with a marble 3x6 subway tile. Am I overthinking this? is this just a CYA move by them and building the low spots out would work just fine?
Marc
espo21 is offline   Reply With Quote
Unread 11-18-2020, 06:41 PM   #2
You can use a patching compound like Custom's "Fix it all". It sets fast and can be sanded afterwards if it needs it. I'd probably apply it in several thin coats.
It's not by the book but I've used thinset for this in thin coats. It takes longer to set though.
Unread 11-19-2020, 08:31 AM   #3
espo21
thanks Davy I'll take a look at that. I appreciate it
Marc
Backsplash wall is wavy because of drywall mud csquibb Tile Forum/Advice Board 7 02-21-2016 05:50 PM
Wavy kitchen wall - how to level for backsplash Dohboy Tile Forum/Advice Board 3 06-11-2015 10:46 PM
Wavy plaster walls raining on my backsplash parade migace312 Tile Forum/Advice Board 8 01-26-2015 04:21 PM
Glass tile backsplash over wavy plywood wall Sparohok Tile Forum/Advice Board 3 05-10-2013 11:05 AM
Tile over wavy porch? deksza Tile Forum/Advice Board 4 07-30-2009 01:28 PM
