Unread 05-06-2012, 10:03 PM   #1
Do-it-Myself
Removing Cultured Marble Shower Walls
Rob27.....any hints for removing the cultured marble shower walls?
HM
Do-it-Myself is offline   Reply With Quote
Unread 05-06-2012, 10:14 PM   #2
Welcometo the forum, HM.
You deserve your own thread so I'll move this out onto it's own. Give a holler on what you'd like the title to be and any mod who sees this will change it.
Cultured marble walls? They are very typically held on the walls by beads of construction adhesive or silicone. Carefully slit the perimeter of each panel where it's caulked to the wall or adjoining cultured marble. Then position a flat prybar between the panel and the drywall/cement board substrate and start working it loose. It's important to be inline with a wall stud or the prybar is likely to punch a hole before you pry much. Be patient. Take your time and pry from a few locations before prying too hard and you're likely to remove the panel in much bigger sections at a time. Wear long sleeves, gloves, safety glasses, and all the other precautions.
Unread 05-06-2012, 10:47 PM   #3
Marge
Marge's Avatar
Everything Tool Guy said! Be especially careful if/when it cracks or breaks. The edges will be VERY sharp.
Marge------
Marble stone tile over Cultured marble slab shower walls Tap2112 Tile Forum/Advice Board 10 11-30-2015 08:42 PM
Advice on removing cultured tile walls frd1952 Tile Forum/Advice Board 4 02-28-2012 10:25 PM
Tiling Over Cultured Marble Shower Walls? navyson Professionals' Hangout 6 08-28-2010 10:22 AM
Cultured marble shower Kman Professionals' Hangout 13 02-26-2010 07:39 AM
Shower: tile walls/cultured marble pan sldill Tile Forum/Advice Board 6 09-18-2003 06:46 PM
