Old 06-16-2018, 05:09 PM   #1
cai24
Replacing Tile In Front of and Around Fireplace - Gypcrete Subfloor
I am looking to replace the tile in front of my fireplace. I recently purchased a 2nd floor condo and am in the process of remodeling it. I am installing hardwood floors, so it would be a good time to do this. Ideally, I would like to run the hardwood right to the fireplace, but I'm not sure if this would be a hassle. From a code standpoint, I believe this would be okay (electric fireplace). There is a gypcrete subfloor, and I don't how difficult it will be to remove the thinset. The gypcrete seems to crack fairly easily. I did read somewhere that you can install tile over tile. I'm not sure if that's a bad idea, but it's something that I would consider. For the wall, I'm leaning toward AirStone from Lowe's, but I'm open to anything. I don't have any experience with this product. If anyone has used it, I'd be curious to hear your input.
Chris
cai24 is offline   Reply With Quote
Old 06-16-2018, 08:42 PM   #2
Tile over tile is an option if the existing tile is in good condition and well bonded.
The only way to know how difficult it might be to remove the thinset mortar under the existing tile is to try it. Sometimes it's easy, sometimes it's not.
Your condo association knows you plan to install hardwood flooring?
Old 06-16-2018, 11:52 PM   #3
Hi, Chris.
I second CX’s question about the condo association knowing about your plan to install a floor that will transmit noise fairly well into the condo below.
Old 06-17-2018, 10:11 AM   #4
cai24
I already have approval from the HOA for the hardwood floors. It’s the first thing I did when I moved in. I have a good underlayment, and I’ve had no complaints from the bottom neighbor. She is on the board, and she wouldn’t hesitate to let me know if there was an issue.
Chris
Replacing a Tile on our front stairs retiler Tile Forum/Advice Board 28 07-27-2017 07:37 AM
Fireplace (tile in front of) 72lemanscvbl Tile Forum/Advice Board 6 12-21-2015 10:47 AM
Unidentified substrate under tile in front of gas fireplace. scarywoody Tile Forum/Advice Board 3 04-19-2014 06:20 PM
Replacing Vinyl with Tile over Gypcrete JennTile Professionals' Hangout 15 06-23-2008 02:21 AM
Tile in front of a fireplace BBsGarage Tile Forum/Advice Board 7 04-28-2005 12:01 AM
