Old 02-08-2014, 08:00 PM   #1
builder brett
Subfloor question
Hello, Im remodeling my first bathroom on my 1969 house. The bathroom is gutted and I'm about to install my new subfloor. My plan is to install 3/4 advantech with 1/2 inch OSB Board to beef up the floor. I will then install Schluter Ditra and finally tile. This should provide a smooth transition from my bedroom to bathroom.
I've know to glue and screw the first layer of plywood to the floor joist. I have read conflicting information on the next layer of plywood. Do I glue the sheets and screw the sheets together? Should I just screw them to each other? What is the recommended way? I'm worried about floor squeaks by just screwing them to each other.
Thanks for your expertise.
brett
builder brett is offline   Reply With Quote
Old 02-08-2014, 09:45 PM   #2
PC7060
PC7060's Avatar
Hi Brett and welcome,
This article in the JB Forum "Liberry" describes how the second layer is attached at the 1/4 and 3/4 points between the joists. The technique make a big difference in the floor by damping out sinusoidal vibrations in the structure before they get transmitted up to the tile layer.
For example, if you jump on a stiff single layer floor you'll feel high frequency vibrations that resonate for a few seconds. If you do the same thing on a double layer floor with the second layer attached at the 1/4 and 3/4 node points the floor will feel "dead".
Old 02-08-2014, 09:49 PM   #3
PC7060
PC7060's Avatar
Quick follow up, did you run the joists size, span and spacing through the Deflecto tool to verify the floor meets the deflection rating for tile?
Old 06-19-2018, 10:46 AM   #4
Steve C.
Old Link
Hey...I'm very interested in the guide on attaching the 2nd layer sub floor at the 1/4 and 3/4 points....but the link is no longer valid. Is the guide still available?
Thank you.
Steve
Steve C. is offline   Reply With Quote
Old 06-19-2018, 06:07 PM   #5
In our Liberry under Wood Framed Floors, post #11, Steve.
Newbie Deflecto question and subfloor question. gonemob Tile Forum/Advice Board 2 09-19-2012 02:12 PM
Subfloor question DarinJB Tile Forum/Advice Board 27 04-07-2011 04:52 AM
subfloor question BrianML Tile Forum/Advice Board 3 03-29-2009 09:55 AM
Subfloor Question harddy Tile Forum/Advice Board 25 11-26-2008 07:09 PM
Transistion question and subfloor question KurtH Tile Forum/Advice Board 4 11-17-2005 11:07 AM
