Unread 04-30-2022, 08:32 AM   #1
msajeep
Delta faucet install issue with tile
Hello,
I’ve got an issue I’m hoping someone can help me out with. I installed a Delta R22000 rough in valve to use with a Delta Ara 17 series dual shower faucet. I’ve installed a few faucets in different showers before but never had a faucet where you had to leave the plaster guard on. This faucet requires the holes in the plaster guard to be used for the faucet plate to be installed. Unfortunately I removed it.
At this point the shower is already completely waterproofed and tiled and the idea of ripping some of it out sounds awful.
I am considering just drilling screws into the tile and goboard to hold up the plate and then also using caulk around most of the plate to help aid in holding it.
Any issues with this though process?
msajeep is offline   Reply With Quote
Unread 04-30-2022, 08:49 AM   #2
Welcome back, Mike, is this for the same shower project as in this post? https://www.johnbridge.com/vbulletin...d.php?t=131453
I think I'd want to look at the feasibility of cutting back the tile and Go Board enough to expose the threaded holes of the shower valve body. Does the valve body also have water stop valves incorporated into the body? Ideally you'd want those accessible, too. A Dremel with appropriate bit would probably do the trick, though would be slow going.
Otherwise, you'd have to drill holes into the tile of the right size to accept a plastic anchor. The Go Board won't hold the anchor. You'll need to cut the screws to length, and it might be a challenge to get those cut machine screws to thread into the anchor. Or, if you measure carefully and drill larger holes, you might be able to screw into the threaded holes in the valve body.
Unread 04-30-2022, 08:58 AM   #3
msajeep
Thanks for the reply.
The rough body does not have holes in it to accept the screws. That’s why I’m having the issue l. Like you, I assumed it did as well. The holes are actually part of the plaster guard which is supposed to stay after the install. I don’t have this player guard anymore. That’s why I’m looking at some alternatives. I do have access from behind and in theory could also put up some blocking to hold up with wood screws in them.
I guess I just figured this plate shouldn’t need much to hold it in place.
Unread 04-30-2022, 09:03 AM   #4
That cover plate won't need much to hold it in place. I've got two towel rods anchored in tile that see way more stress on them than that cover plate will ever see.
Unread 05-01-2022, 07:39 AM   #5
If you’ve got access from the back, I suppose you could use fender washers and nuts to secure the screws. But installing and removing them would require two people, one on either side of the wall. Not to mention there’s a possibility of them being difficult to remove years down the road from hard water crusties (even with stainless hardware) if you needed to remove them to service the mixer valve.
I’d probably prefer using some would blocking back there, then switching to oval-headed stainless wood screws to secure the escutcheon plate.
Unread 05-07-2022, 02:20 PM   #6
msajeep
Thanks everyone. I was able to get the plate on with some screws and washers. This thing has been a giant headache. After getting it all installed it was working great. Now when it’s turned on there is a real loud whining noise. Any suggestions before I just rip the wall open and remove this thing.
Unread 05-08-2022, 07:08 AM   #7
Sounds like an obstruction/excess solder in the mixer/pipes. Have you turned off to explore for such inside?
Unread 05-08-2022, 08:37 AM   #8
madmantrapper
I had to google that thing, I don't think I ever saw a valve that the escutcheon mounted the the plastic.
Paul
madmantrapper is offline   Reply With Quote
Unread 05-08-2022, 09:05 AM   #9
Agree with Bubba. Was there anything in the valve installation instructions about flushing the valve, Mike?
Unread 05-08-2022, 12:36 PM   #10
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
It was working great after the install and now its making noise? Working great as in a test to see if it works? Does it have the shower head on now versus not having it on before. Sounds like an obstruction or water metering device.
Pull the shower head if there is one on it and run some water through it and see if the noise goes away.
Travis
It's just a clever handle.
Unread 05-08-2022, 06:06 PM   #11
DOes the rough-in valve have integral shutoff valves? If so, are they fully open?
Shut the main water valve off, pop off the handle(s), remove the cartridge, have someone turn the main valve back on for maybe 10-seconds to flush out the lines, and put things back together and see what happens.
If this is a tub/shower, some spout diverters can make some nasty sounds, but usually not when new.
Unread 05-08-2022, 09:05 PM   #12
Snets
Professional Weekend Warrior
Snets's Avatar
I would love to help on this one but I live in CA and we don't talk about shower valves that emit more than 1.8 GPM since July 1, 2018. I'm peeking through the blinds now to see if this post generated a surveillance....
All kidding aside, this is a good thing as it has caused manufacturers to produce showerheads that are more effective with less water. Sorry!
Unread 05-09-2022, 12:49 PM   #13
msajeep
Thanks for the replies. Yes it was working fine before I put the shower heads on. I’m going to try removing the cartridge and running it. Then running it without the heads on.
Issue with new residential bathroom tile install AZCAL Tile Forum/Advice Board 32 08-05-2019 11:05 PM
Fill "divots" around holes for faucet install dinologic Tile Forum/Advice Board 7 06-20-2017 02:51 PM
Tile install quality issue Scott_in_VA Tile Forum/Advice Board 10 08-07-2015 07:19 PM
Issue with V-caps on tile countertop install gottwins Tile Forum/Advice Board 5 02-10-2009 04:32 PM
Delta Plasterguard issue holybuzz Tile Forum/Advice Board 3 09-14-2008 05:38 PM
