Thanks, yes, I'll confirm compatibility or else use regular drywall in the shower.
I have yet to put anything on the walls to keep them dry. Still investigating the right way to do this. Outside is under dirt, and I'm not digging, so anything I do will be inside. It's a walk-out basement (the bathroom is against the side with a full-height concrete wall), well-drained on a slope, and there's no visible moisture -- and I know there can be invisible moisture coming through the concrete.
I'd sure welcome recommendations about how to proceed with the walls. So far I have: some kind of waterproof coating on the concrete wall, stud wall spaced away from the concrete, insulation (rigid foam?) between the studs, vapor barrier (not in the shower), drywall. I hope this is not too off-topic for this forum. I've noticed this is a wide-ranging group.
Pam
