Unread 05-26-2010, 07:52 AM   #1
thetilegirl
thetilegirl's Avatar
hellllloooo again - lookin for input from ya'll
Question of the day: 17x17 3/8" porcelain in unheated but interior poolhouse/cabana in northestern US. Asked for 1 1/4" ply. What's everyones opinion on appropriate membranes/underlayments/setting materials?
Shannon
Schluter Systems Territory Manager for New Jersey and the NY Metro Area
thetilegirl is offline   Reply With Quote
Unread 05-26-2010, 08:04 AM   #2
opiethetileman
opiethetileman's Avatar
I myself hate to say it but ditra would be the way to go. Unless ya mud and lathe it.....
see what the smart folks say the crazy guy gave his answer...and oh yeah I wouldnt use anything byt laticrete to set it with
opiethetileman is offline   Reply With Quote
Unread 05-26-2010, 08:23 AM   #3
thetilegirl
Hmmm ok. Bein a ditra girl, I'm all for tht. Well, not ALL I guess, for the same old unmodified vs modified on top thing. As I was just sayin to shaughnn on facebook, I'm in love with mapei LFT right now but worrying bout any mod curing under 17's over ditra even if I fill it before setting. Got no problem with mudding it but then need membrne or just go? It will def freeze, will get wet but not soaked. Hmmmm
Shannon
Unread 05-26-2010, 08:28 AM   #4
opiethetileman
i would membrane it then...i just did a bathrooms floor mudded it and then used kerdi over the floor and shower and bathroom floor as well
i still say ditra and laticrete the thing... and you did say you are on a wood subfloor
Unread 05-26-2010, 08:57 AM   #5
Chad Deiter Company
Making Cents of It All
Chad Deiter Company's Avatar
Send a message via Yahoo to Chad Deiter Company
I would see how the floor is and either do the 1 1/4" ply or mud the thing if it's way outta wack. The Ditra is a must for this in my opinion. And I'd use a Laticrete 252 or Versabond but that's just me.
Chad from CDC54.com " You Dream It and We Create It "
Southern California Custom Tile and Stone Installation
Chad Deiter Company is offline   Reply With Quote
Unread 05-26-2010, 10:24 AM   #6
Jimmy Reed
Rock Solid Tile, Inc. Glass Tile Pools & Spas
Send a message via ICQ to Jimmy Reed
I'd say membrane on ply, paper & wire & float with 3701 Fortified, Hydroban, 254 and whatever grout, maybe Permacolor. Should be good to go.
Jimmy Reed
Jimmy Reed is offline   Reply With Quote
Unread 05-26-2010, 10:25 AM   #7
Jimmy Reed
Can't see the pic too well, but are you tatted up or is that just some sheer floral top?
Jimmy Reed
Unread 05-26-2010, 11:24 AM   #8
Jimmy, clarify your installation suggestion a bit. Looks like more than one operation.
Yes, the girl has some nice artwork on her.
Unread 05-26-2010, 12:48 PM   #9
I vote mud or Ditra.
Unread 05-26-2010, 04:44 PM   #10
HS345
Tile Contractor
HS345's Avatar
I would go with Ditra/Versabond, and Kerdi Band the seams.
The ultimate would be Ardex FB-9L under, and over the Ditra, and Kerdi Band the seams with Laticrete 317, or Versabond.
The name's Greg
Unread 05-26-2010, 04:50 PM   #11
opiethetileman
wow and my answer was right the crazy guy...my brain is starting to come around
Unread 05-26-2010, 06:33 PM   #12
Bill Vincent
Tile Contractor
Bill Vincent's Avatar
Shannon, Either Ditra or 1/4" Durock. I do alot of places up here that are shut down during the winter. Although the Ditra works with the unmodified, I'm always a little skittish being the temp extremes the tile will see. Keep in mind, alot of people winterize their summer homes up here-- antifreeze in all the water lines, and so forth, so the tile will see prolonged subzero temps during the winter. For that reason, I prefer the cement board and 317/333, along with a modified grout, or even epoxy.
Bill
Unread 05-26-2010, 06:45 PM   #13
One more vote for ditra and lightly modified......
Unread 05-26-2010, 06:49 PM   #14
Crestone Tile
Gonzo!
If I use Ditra outside, I use rapid set. Yes, I know a quality unmod is supposed to be sufficient. I am nervous about the bond to the tile side with freeze / thaw cycles, though.
If you want to use LFT, talk to Mapei about what to do whether AquaD, 315, or whatever. They have an option for everything.
Matt
"Shut it down!"
Crestone Tile is offline   Reply With Quote
Unread 05-26-2010, 11:08 PM   #15
gueuzeman
Well, with Hydroban and 254 Platinum, I believe you could get a lifetime garranty from Laticrete. LFT is supposed to be some good stuff, so I'll agree with Crestone and say talk to Mapei.
How's the new saw?
gueuzeman is offline   Reply With Quote
Lookin for jobs in Gainesville FL Tile Trowelki Professionals' Hangout 7 02-18-2009 04:45 PM
Bath Remodel, Curbless Shower hopes, lookin for some help! markeyro Tile Forum/Advice Board 5 01-07-2007 12:21 PM
lookin to talk to someone with a sawmaster sdt-1000 elfkind Professionals' Hangout 14 03-04-2005 07:09 AM
Here's lookin at you Davestone The Mud Box 12 09-09-2004 05:54 AM
