Unread 05-01-2021, 12:56 PM   #1
superchief
latex with grout
Large format white tile on floor and walls with 1/16 joints ... designer wants to mix white latex paint with Mapei avalanche grout to make it whiter, says he has done this before.
I told the customer I cannot warranty it but does anyone have experience doing this and did it cause any issues?
Superchief
superchief is offline   Reply With Quote
Unread 05-01-2021, 01:14 PM   #2
jerrymlr1
I would suggest getting paid for what you've done and then let the ill informed designer do the grouting, with him accepting all liability.
Jerry
Unread 05-01-2021, 01:30 PM   #3
smifwal
Avalanche is supposed to be the whitest grout available. If she wants whiter than let her paint it when you're done but I would definitely not mix latex paint with grout
Unread 05-01-2021, 07:10 PM   #4
Jason@mapei
Jason Cantin Mapei Technical rep
Jason@mapei's Avatar
We actually Make a White In Ultraocolor Plus Max.
https://cdnmedia.mapei.com/docs/libr...rsn=3665c344_0
https://www.youtube.com/watch?v=PeA5Fl53v9c
Jason
Jason@mapei is offline   Reply With Quote
Unread 05-01-2021, 10:53 PM   #5
I consider that silly and wouldn’t dare void the manufacturer’s warranty for such a request.
Just because someone ‘has done something before’ doesn’t necessarily add any credibility to something. It may show that they are creative in their thinking...or it may indicate something much less flattering. But you’d have the chemists who formulate the grout rolling their eyes if they knew someone had been mixing paint into their grout.
Unread 05-02-2021, 09:10 AM   #6
superchief
white mapei
we tried the white as well as avalanche, avalanche actually looks whiter
considering an alternate idea to propose, test a white grout paint - extra step but at least you don't mess with the grout formula and are using the two products as designed.
Superchief
Unread 05-02-2021, 09:13 AM   #7
Are any of these tiled walls in a “wet” area? I ask because the grout colorants you speak of may or may not be rated for a wet area.
Unread 05-02-2021, 09:26 AM   #8
superchief
good point, I'll have to check as this is the entire bathroom including the shower.
Another thought occured since they are 1/16 joints is to use white silicon caulk with a biocide like GE II instead of grout
Superchief
Unread 05-02-2021, 04:09 PM   #9
One thing grout does that caulk won't is to literally support the edges of the tile. When they are not well supported, and you roll or place a point load on a joint, you can crack the edge of the tile(s) involved. IMHO, not a good idea!
Unread 05-03-2021, 06:17 AM   #10
superchief
good point, works on walls but risky on floors
Superchief
Unread 05-03-2021, 10:19 AM   #11
Welcome. Please check your PMs.
Latex Grout bmoore Tile Forum/Advice Board 1 09-24-2009 09:40 AM
Latex modified thinset vs. liquid latex additive Paisley Tile Forum/Advice Board 24 08-10-2008 01:49 PM
Unsanded Grout + Latex in place of Sanded Grout rctong Tile Forum/Advice Board 4 05-30-2006 06:09 PM
latex instead of grout Judy Z Tile Forum/Advice Board 1 12-17-2004 02:36 PM
latex in grout??? Wendi Tile Forum/Advice Board 7 11-05-2003 06:53 PM
