Unread 04-20-2021, 08:43 AM   #1
BillNC
Enrich N Seal with Microban?
Apparently Aqua Mix no longer makes Enrich N Seal with Microban. Suppliers still show the picture of the 1 pint bottle that says "Microban" but the current bottles that I received when ordering do not say Microban.
I'm planning on using the Enrich n Seal to seal the grout joints on the walls of a shower. Wall Mart sells Microban 24 All Purpose in a pump spray bottle which does not include citric acid. The ph of this product is 9 (basic).
(The Microban 24 Bathroom with citric acid is acidic.)
So, I was going to treat the grout joints with the Microban 24 All Purpose, let it dry throughly, then seal the grout joints with Enrich N Seal.
The wall tile is a porcelain tile with a polished finish. I did a test on a scrap piece and was able to remove the Enrich N Seal even after 5 hours (24 hours if I used rubbing alcohol).
Does anyone see any problem with this?
Thanks, Bill NC
Bill
BillNC is offline   Reply With Quote
Unread 04-21-2021, 09:08 AM   #2
Hi Bill,
Looks like the product is used for natural stone. I don't see a mention of porcelain tile, which by the way won't accept a lot of sealer. Here's the page:
https://www.custombuildingproducts.c...ch-n-seal.aspx
You can contact Aquamix here: 800-272-8786
Unread 04-22-2021, 07:16 AM   #3
BillNC
Thank you. I would only be sealing the grout joints. I did a test on being able to wipe it off the tile, and it came off readily even after several hours.
Bill NC
Bill
Unread 04-22-2021, 01:07 PM   #4
jerrymlr1
Hi Bill. Are you using Enrich n Seal just to darken the grout joints?
Jerry
Unread 04-23-2021, 10:47 AM   #5
BillNC
To seal and darken the grout joints. I've used it on the grout on floors before and really like how it performs in both darkening, and sealing the grout.
Bill NC
Bill
Aqua Enrich and Seal MidwestTile Cleaning, Restoration and Sealing 10 11-14-2009 04:35 PM
Enrich N Seal Over Ultra Seal s25abc10301 Cleaning, Restoration and Sealing 3 11-27-2008 04:10 PM
511 Seal & Enhance or Aquamix enrich and seal titan7 Cleaning, Restoration and Sealing 7 06-10-2008 12:56 AM
What to use over Aqua Mix Enrich 'n Seal TJ Cleaning, Restoration and Sealing 13 04-17-2007 05:52 PM
Confusion about Enrich 'N' Seal Unregistered Tile Forum/Advice Board 5 12-17-2004 01:57 PM
