Unread 03-04-2004, 02:46 PM   #1
Kanukshowerguy
Floor heat insulation between floor and heat wire?
Hi all, I am planning on installing electric floor heat in my basement bathroom on a concrete floor.
I am wondering if any of you have heard of a product called Wediboard?
http://www.wedi.de/english/index.html
If so what are your thoughts.
It is cement board made in Germany and it sandwiches a layer of insulating foam between to layers of cement board.
I want to insulate my heat wire/tile from the cold concrete floor thus reducing the electricity needed.
Then the floor won't act like a big heat sink.
I am looking at the 1/4 think product. Although I have yet to find anyone to supply me with it without a huge shipping charge, that would be my next question.:0)
Kelly
Kanukshowerguy is offline   Reply With Quote
Unread 03-04-2004, 04:33 PM   #2
Steven Hauser
STT Owner
Steven Hauser's Avatar
Hi Kelly,
Well you are right about the heat radiating down as well as up. I talked to our friends at Warmly Yours and they suggested using a cork underlayment.
It has a great R value. Don't get me wrong, if you can find Wedi it will work just like you thought.
Good luck, Steven
Clean
Sealed
Safe
STT Sealers with Attitude!®
Unread 03-04-2004, 04:39 PM   #3
Kanukshowerguy
Cork? Hmm seems that would go against the whole idea of a good solid backer board for tile instillation?
Is there a cork product that would be approved for under tile instilation?
Would you thinset it to the concrete and then applie the heat wire?
Kelly
Unread 03-04-2004, 04:53 PM   #4
Steven Hauser
STT Owner
I am a dope I didn't know you wanted to tile over it.
I'll think about it and get back to you.
Again, I'm sorry.
Clean
Sealed
Safe
Unread 03-04-2004, 05:09 PM   #5
Kanukshowerguy
DON"T be sorry! It was I that never indicated that it was tile until the last post.
I just appreciate that people are so willing to help.
There is another product that HD has called Ryno board. I'ts about 1/8th or maybe 3/16th thick and they (the highly knowledgable HD employees) <grin> say it's approved as a tile backer board?
Even if it is alright to use I don't know is if there would be any R value in using it?
I have not found anthing on the web either?
Unread 03-04-2004, 05:32 PM   #6
Kelly,
Click the Warmly Yours banner at the top right of this page. They have a procedure for using Wedi.
I don't think anyone uses Rhino Board for that application.
Unread 03-04-2004, 09:16 PM   #7
stullis
Flooring Installer
Permabase would work as well. It might be more readily available to you.
Seems to me that cork has been used but I have never done it.
Scott
stullis is offline   Reply With Quote
Unread 03-04-2004, 09:31 PM   #8
e3
bonsal has pro panel (like wedi)
Eric
Noble Company
Unread 03-05-2004, 08:13 AM   #9
Steven Hauser
STT Owner
Thanks Scott & Eric,
Both are good ideas.
Clean
Sealed
Safe
Unread 03-05-2004, 01:12 PM   #10
Kanukshowerguy
Thanks for your input guys but nop luck so far.
Found a supplier of Wedi board but they will only ship it in 30" X 36" sheets and a pretty high shipping cost.
The Pro Board people say I'm out of luck unless I order a pallet of 50 sheets.
I think the Permabase only has a solid core board? Or did I not look in the right place?
If so then I think the Dura Rock that I have access to would be the same thing but I'm not sure if it would be worthwhile to put that down. Not sure if the R value would be high enough to even bother if it does not have a foam in the middle?
Any other ideas thoughts?
Thanks again.
Kelly
Unread 03-05-2004, 07:41 PM   #11
flatfloor
"da Leveler"
flatfloor's Avatar
Kelly did you talk to Warmly? Maybe they can arrange something.
Jim Buckley
Tile Calculator
New Here? Read this!
Unread 03-05-2004, 08:17 PM   #12
stullis
Flooring Installer
The permabase has some foam beads in it. Probably has very little insulating value but would be better than durock.
One of the local stores was trying to sell a product called Insulayment. I think the manufacturer was MidWest Padding. I think I would be willing to try going over cork before using it though.
Go to www.google.com and do a search on insulayment and one on "cork under ceramic".
Scott
Unread 03-07-2004, 09:12 PM   #13
kanuckshowerguy
Guest
Posts: n/a
Thanks guys, I will let you all know what I use and how it works out!
