Unread 12-14-2012, 01:36 AM   #1
Big Joe
custom levelquick over peel and stick membrane
i,v always selflevel first then use peel and stick membrane , thought i could get away with it but floor is worst then i thought. can i still use customs rapid setting levelquick over customs peel and stick membrane
Joe
Big Joe is offline   Reply With Quote
Unread 12-14-2012, 08:41 AM   #2
pgc555
Joe,
CBP tec support would be the best place to get the "official" answer
Phil,
http://www.edgestripkits.com/
pgc555 is offline   Reply With Quote
Unread 12-14-2012, 09:32 AM   #3
I doubt that's going to work. Here's the TDS for that product.
http://www.custombuildingproducts.com/TDS/TDS-108.pdf
Unread 12-15-2012, 12:24 AM   #4
Big Joe
custom levelquick over custom peel and stick membrane
iv allways flooded the floor with rapid setting level quick then used a peel and stick membrane.this time i thought i could get away without the self leveling but the floor looks worst than i thought . i,d like to self level before tileing but i,v allready installed the peel and stick i,m considering using a small notch with thinset , letting it dry then self levelling , has anyone selfleveled over membrane without any problems. im thinking it should be ok considering guys that mud over membrane all the time ,thanks joe
Joe
Unread 12-15-2012, 09:35 AM   #5
Topspin
SchluterUgrad
Topspin's Avatar
Start here
Then call Custom Building Products tech support. They will tell you - No. Then you can ask them what your options are.
Btw what is your floor structure - plywood, concrete?
Unread 12-15-2012, 09:58 AM   #6
Joe, posting the same question in more than one place usually results in confusion and duplication of response. As you can see, you're gonna get the same answers, anyway.
Installing SLC and deck mud are two completely different concepts and what works for one method is not gonna be at all the same for the other.
Unread 12-15-2012, 10:04 AM   #7
Seems to me, SLC makes it's own dust even after you mop it. I have tried to get Protecto Wrap to stick to it and had problems, even had primer down first. Maybe it was a bad batch of PW, can't say. Joe, you say this is how you usually do it, have you had problems trying to get the Peel and stick to bond to the SLC?
Unread 12-15-2012, 10:17 AM   #8
Whenever putting a peel and stick over SLC we let it set a few days, prime, apply the fabric, then walk all over it for a few days while we work on the walls. Walking all over it seems to do a great job of smashing it into the SLC. We cover it with cardboard to protect the fabric while working on the walls.
Tiling over peel-and-stick primer? eeebop Tile Forum/Advice Board 3 09-09-2012 10:06 AM
Custom Building Products Custom Blend CharlesW Tile Forum/Advice Board 15 02-20-2009 11:51 AM
Custom shower pan Fibreglass vs. membrane pdunlap Tile Forum/Advice Board 3 08-01-2005 09:09 PM
Peel and stick tile TheGreatSatan Tile Forum/Advice Board 11 09-14-2003 04:57 AM
