Unread 04-19-2021, 06:25 PM   #16
pianobarry87
[mention]ss3964spd [/mention] craziness instead. Considering that the wall is basically 4x8 I can easily throw a sheet of dry wall and it will cover up all of this nonsense. I was planning on changing the baseboard anyway.
Barry
pianobarry87 is offline   Reply With Quote
Unread 04-19-2021, 06:56 PM   #17
pianobarry87
[mention]Carbidetooth [/mention] The sink area backsplash concerns me the most mainly because I’ll probably end up having a sliver tile on the top end so I will need sufficient support there. It’s a bit of a mess. I think you were saying to patch larger gaps with drywall and the rest with tape plus joint compound and sand everything smooth. I can take the faucet out to make this easier.
Or could I cut out the existing dry wall and slap on cement board there.
Barry
Unread 04-20-2021, 06:55 AM   #18
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Yes, specifically drywall, PL Premium construction adhesive, fiberglass mesh tape and setting drywall compound, (will be powder mixed with water), because it's stronger.
A deft touch with various widths of drywall knives will achieve a surface that doesn't need to be sanded much, if at all.
If you're not familiar with all I'm talking about, it's not in any "best practice" book and I hesitate to recommend it for someone new to the game. When you write "Slap on cement board" it gives me pause as I don't slap anything up. I assess and calculate what will give result I desire and not compromise my client or me.
It's a jungle fix and comes with a the qualifiers "Your mileage may vary" and CX's notable "worth price paid".
Peter
drywall prep b4 tiling ovillegirl Tile Forum/Advice Board 3 10-25-2016 09:00 AM
First Time Poster - Concrete Slab Prep mdenton Tile Forum/Advice Board 5 09-30-2016 03:38 PM
Fireplacing Tiling Prep RJMorrow Tile Forum/Advice Board 2 11-23-2008 02:35 PM
Pre-tiling prep/plumbing wilburleft Tile Forum/Advice Board 3 05-29-2006 11:15 AM
prep & tiling around new tub carmand Tile Forum/Advice Board 11 10-16-2002 04:40 PM
