Since we can't access the pipe except by chipping away concrete, how do we get the drain to code?
By chipping away concrete.
Seriously, it's not has hard as it sounds, although I would want to know where it joins a larger pipe before I started. It's probably only a few feet.
Crestone Tile & MudGuy, your posts imply that there are difficulties with tile ready pans. What experiences did you have?
Those guys don't necessarily have anything against Tile-Redi; they just like playin' in the mud.
I actually used a Tile-Redi pan in my shower. I'm sure it will last a good long while, but I wouldn't do it again.
First, the instructions assume you can access the drain from below. Obviously you can't with a slab. Mine is on a slab too, but it was a harrowing pain in the @ss to get it set right.
Second, you have to set tile to the pan with the epoxy thinset that comes with it. If I never have to use epoxy thinset again, it will be too soon.
Bottom line, the product does work, but it's expensive, and it really isn't easier than building a mud pan from scratch - especially with help from this forum from guys like Crestone and MudGuy.
