This is a great site - thank you for making such an excellent forum available.
We've finally started the project of removing the worlds worst rust colored carpeting from our den, and some of the hardest to maintain nearly white linoleum from the eat in area of our kitchen which joins the den.
Beneath the den is a crawl space, with 2x10 fir joists on about a 13ft clear span on 16" centers.
according to the deflecto here - that's a thumbs up for ceramic tile, thumbs down for natural stone.
Here's the rest of the story:
over the 2x10 joists is 3/4" plank subfloor
over that subfloor is 5/8" plywood
over that is linoleum glued down tight which I roughed up with a rotary sander and 36 grit (per mortar bag directions)
then mortared down 1/4" hardibacker
we've gone through 24 sheets of hardi, over 1000 screws, and nearly 3 bags of mortar (hardi screws counter sunk and filled, seames taped and filled)
The plan now is to lay 18x18 porcelain daltile over the hardi (~3/16" thick tile)
I realize this is a lot of weight - and when finished the floor will be nearly 1-3/4" thick over the top of the joists....
Do I need to go into the crawl space and put in a beam in the center of the 13ft span supported by short steel jack posts on say 12"x12"x2" concrete pads?
