Hello Joe,
I've got a similar installation I'm currently working on and here's the solution I've chosen.
Set walls with 3/8" stone, using scraps cut down to the width of the glass band (w/ joints) to space the field tile. Then I plan to use strips of Custom's "Easymat" bed in thinset to build up the channel for the glass before the mosaic is installed. The glass is an Oceanside Glasstile product and is 1/4" thinner than the field tile. It's also a face-mounted mosaic instead of your mesh-mounted but I think the technique would still work.
By doing it this way, I figure I can set all of my walls without obstruction, using my level to bridge the channels. I can then use a beating block to compress the mosaic onto plane with the stone after the stone's secure.
Best of luck,
Shaughnn
