adding dry grout mix to wet caulk for faux calk?
Saw on a DIY TV show a trick where they folded a piece of paper to hold dry grout powder and dusted the surface of wet caulk with the dry grout mix, then set it into the surface slightly with their finger to make the calked edge match the grout.
This was on a floor where they didn't have colored calk to match the grout. I am considering the same technique at the base and corner where a slate backsplash (whole wall under cabinet) meets the black granite counter top and expansion joint. I plan to give the powdered grout coated calk a got of polyurethane to protect it and make it match the grout sealed with color enhancer (low gloss)
Question:
Any one ever try this technique before? Did it work for you? Do you think the coat of poly will protect the powder on the caulk enough to stand up to cleaning the counter top?
Grant
