Wall Mud or Floor Mud First when shower is hot mopped
Doing a Shower as follows:
- Plywood subfloor
- Pre-sloped with 3/4" ply with cast iron drain
- Hot mopped floor and up 10 " on sides
- Covered walls with greenboard and overlapped hot mop on walls by 3 inches.
- Bottom of green board sits 7" above hot mopped floor
- Was going to cover green board walls with vapor barrier before I mud.
- As well going to apply diamond lath to walls
Now I am read to mud wall and floor. So my questions are:
1) how far above the hot mopped floor should the lath stop?
2) do I mud the wall or floor first ?
3) I am concerned that the greenboard stands proud of the hot mopped walls by 1/2". As I mentioned, the bottom of the greenboard is 7" above the hot mopped floor. Does that mean I need to wrap the lath beyond the bottom of the greend board and downward "x" inches and then backfill in the 7" band with an extra 1/2" of wall mud (in addition to the normal 1/2" wall mud)???
David
