Unread 08-02-2013, 09:55 PM   #1
Matt Lengeling
Deck Mud Calculator with offset drain
hello, I use that calculator all the time but im doing a shower that just ramps down to a wide drain on the far wall. Is there a mud calculator for that?? Thanks
Matt
Matt Lengeling is offline   Reply With Quote
Unread 08-03-2013, 12:26 AM   #2
That's just basic math, Matt. If your mud slopes to zero at the drain, you just multiply length times width times height of your mud at the thick end and divide by two to get the required volume.
If your mud is thicker than zero at the drain, calculate the volume using the height at the drain and then calculate the sloped portion as above and add the two volumes.
Err on the high side, mud's cheap, eh?
Unread 08-03-2013, 06:31 AM   #3
wilander
always buy more than you think you need. i calculated 5 bags of mud mix. thought i would buy another just in case - only $6. glad i did - needed 3/4 of the sixth bag. my math must have been off somewhere.....
Richard
wilander is offline   Reply With Quote
Unread 08-19-2013, 11:42 PM   #4
Matt Lengeling
Deck mud ratio
I read in johns article the proper ratio is 5parts sand to 1 part Portland,5:1, What is the ratio when using sand topping mix instead of Portland. Thankyou for you help.
Matt
Unread 08-20-2013, 12:10 AM   #5
dhagin
Check the "Deck Mud Calculator" in the Liberry. There's info on both ratios.
dana
Unread 08-20-2013, 12:44 AM   #6
Matt Lengeling
Thankyou that's awesome. I have a long narrow drain at one end of the shower. Does the have a calculator for that? Thanks for your help sir
Matt
Unread 08-20-2013, 08:58 AM   #7
Matt, it'll help if you'll keep your project questions on one thread so folks can see (eventually?) what you're working on and what's been previously asked and answered. We can give it a more generic title any time you'd like to suggest one.
See post #2.
Thanks for the deck mud calculator Kirk Grodske Tile Forum/Advice Board 4 10-25-2007 04:56 PM
Calculators for Deflecto, mud, and tile Mike2 Reference Liberry :-) 2 06-15-2007 08:24 AM
deck mud calculator nelly Tile Forum/Advice Board 6 03-03-2007 07:08 AM
Deck Mud Calculator - Cool, but... Dan Clark Tile Forum/Advice Board 4 07-03-2006 11:20 AM
