Unread 07-06-2012, 01:39 PM   #1
T_Hulse
Tile Contractor
T_Hulse's Avatar
Urethane grout & expansion joints
I'm wondering if there has been any thought to reducing the frequency of expansion joints on a floor with a "permanently flexible" grout on bigger jobs? It just seems like a waste to put in a bunch of soft joints if every grout line is already flexible. Is there any reason to think that urethane grout will not move with the floor?
Tom Hulse
Visit my web site here
Unread 07-06-2012, 04:52 PM   #2
dhagin
Does the grout manufacturer say anything about it Tom? I haven't used any urethane grout yet, but are you saying that the cured grout is relatively soft like caulk or other movement joint materials?
dana
Unread 07-06-2012, 05:29 PM   #3
In discussion I had with one such manufacturer's rep, Tom, it seemed they think it would be better than cementitious grout, but they were not prepared to say it would eliminate the need for movement accommodation joints.
The stuff's not at all squishy when cured, Dana. Not as brittle as cementitious grout, of course, but still very, very firm material.
I think it'll take some side-by-side field testing to really sort it out, and that's not gonna be easy to find. Then you gotta wait maybe twenty years for the cementitious side to tent while the urethane side doesn't. Maybe they'll come up with some sort of meaningful testing.
Sure would be a marketing tool for them if it works, though.
Unread 07-06-2012, 06:07 PM   #4
Ken
welchtile.com
You should still continue the use of expansion joints like you normally would when using cement based grout.
Ken
Ken is offline   Reply With Quote
Unread 07-07-2012, 07:05 PM   #5
Brad Denny
CTEF Director
Brad Denny's Avatar
Hiya Tom,
I brought up the same question a while back here.
Brad
Unread 07-07-2012, 07:11 PM   #6
Bill Vincent
Tile Contractor
Bill Vincent's Avatar
Give it ta Mr. Whipple. He'd be all over it.
Bill
Unread 07-07-2012, 10:01 PM   #7
Lazarus
Lazarus's Avatar
That's bad, Bill.......LOL.....
Laz...
A man who carries a cat by the tail learns something he can learn in no other way.
Unread 07-07-2012, 10:05 PM   #8
doitright
doitright's Avatar
Hi Bill
I have to agree!
John Koessler
Unread 07-07-2012, 11:49 PM   #9
evan1968
Not So Senior Contributor
evan1968's Avatar
Whipple does tests for the tests! (Deleted)
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Unread 07-08-2012, 09:22 AM   #10
Craig, we don't abide name-calling here, no matter how unpopular the callee might seem to be. Don't do it again.
Unread 07-13-2012, 09:11 PM   #11
madronatile
Is it ok to caulk a urethane grout installation the next day, or is any water a no-no?
Matt
www.madronatile.com
Unread 07-13-2012, 09:17 PM   #12
Bill Vincent
Tile Contractor
I've never gotten any problems from it
Bill
Unread 07-13-2012, 10:23 PM   #13
Topspin
SchluterUgrad
Topspin's Avatar
Far as I heard the answer is NO. Yes the urethane is flexible. But I believe I remember it's compressive strength is extremely high. Somewhat of a oxymoron, but it is supposed to be very hard but flexible when twisted or bent.
The way it was explained to me by our regional rep, is think of it as as hard as a epoxy grout, yet flexible if twisted or bent. If you put it in a vice, it would not compress. So it would provide no flexibility in terms of prevention of tenting.
Unread 07-14-2012, 06:32 AM   #14
Bill Vincent
Tile Contractor
Yeah, but when it DOES tent, it won't crack!
Bill
Unread 07-14-2012, 01:35 PM   #15
dhagin
dana
Difference between Urethane Grout & Epoxy Grout? HomeDepotAssociate Tile Forum/Advice Board 15 07-09-2012 09:31 PM
expansion joints in shower w/ epoxy grout snomachine Tile Forum/Advice Board 3 04-12-2008 11:04 AM
Expansion Joints: Caluk or Grout pamk Tile Forum/Advice Board 3 07-27-2005 05:45 PM
Steam Shower Questions - Vapor Barrier & Expansion Joints blieb16 Tile Forum/Advice Board 21 01-10-2005 08:44 AM
Guidelines for grout line expansion joints? odinsrage128 Tile Forum/Advice Board 4 08-10-2004 11:30 AM
