Unread 02-18-2010, 08:22 PM   #1
John96
How to cut a 2" waste line
What is the best way to cut a 2" waste line in a shower that I have no access to underneath. I have seen someone post a picture of a tool that you insert it into the pipe and cut the pipe from the inside out. I am wanting to replace a clamping drain to a kerdi drain. I did a search but could not find anything. Anybody know what I am talking about?
John
John96 is offline   Reply With Quote
Unread 02-18-2010, 08:41 PM   #2
TileArt1
TileArt1's Avatar
Hey John,
That particular tool is called, surprisingly enough, a pipe cutter. You can order them online if you can't get a hold of one locally.
I have also done it by placing a regular cutting wheel on my dremel and sticking it down into the drain.
Roger (The FloorElf)
Unread 02-18-2010, 08:47 PM   #3
John96
Thanks! Did the dremel melt the pvc creating burrs? High RPM's?
John
Unread 02-18-2010, 08:51 PM   #4
i prefer these but they sometimes can rattle loose off your drills chuck.
Unread 02-18-2010, 08:54 PM   #5
Chad Deiter Company
Making Cents of It All
Chad Deiter Company's Avatar
Send a message via Yahoo to Chad Deiter Company
Ricks right definitely have a magnet ready to retrieve said tool from the drain.
Chad from CDC54.com " You Dream It and We Create It "
Southern California Custom Tile and Stone Installation
Chad Deiter Company is offline   Reply With Quote
Unread 02-18-2010, 10:20 PM   #6
You can put a wad of toilet paper down the drain just below the cut line. If the cutter falls out it won't go any further than that.
Unread 02-18-2010, 10:24 PM   #7
Chad Deiter Company
Yah but then you don't get to do dig it out of smelly old hair infested trap water ..
Unread 02-18-2010, 10:27 PM   #8
Hey, I am eating here !!!
Unread 02-19-2010, 09:08 AM   #9
johnfrwhipple
Pipe cutters sold at plumbing wholesalers
Look at plumbing wholesaler for the pipe cutter.
Mine is by Masters...
johnfrwhipple is offline   Reply With Quote
Unread 02-19-2010, 10:13 AM   #10
K.
I found that the dremel with the regular cutting wheel did create some burrs from melting the ABS, but they were easy to pull off and the actual edges of the cut surface were quite sharp.
-Jonathan
K. is offline   Reply With Quote
Unread 02-19-2010, 10:24 AM   #11
johnfrwhipple
Cutting ABS with a pipe Shooter (Inside Pipe Cutter)
Try this one from Masters.
PS-100
http://www.ksminc.net/files/Masters_Catalogue_KSM.pdf
Unread 02-19-2010, 05:50 PM   #12
They sell them at HD provided the "clerk" can find them for you in the plumbing dept
Unread 02-19-2010, 05:57 PM   #13
opiethetileman
opiethetileman's Avatar
in the plumbing tool isle they are about 9 to 11 bucks now
opiethetileman is offline   Reply With Quote
Unread 02-19-2010, 09:40 PM   #14
John96
Awesome. I will check my homey depot in the morn. For 9-11 bucks it beats cutting up the subfloor. Thank you!
John
kerdi shower drain hole cut 6" instead of max 5" jmatthewsr Tile Forum/Advice Board 8 07-10-2009 09:55 PM
Anyone familiar with "Orbit" tile line? FctryRep Professionals' Hangout 1 01-15-2008 10:19 AM
Cleaning up grout line edges of granite "slab" puckschmuck Tile Forum/Advice Board 5 03-06-2007 08:13 PM
best way to cut a "perfect" drain hole in tile? Bucho Tile Forum/Advice Board 16 02-05-2007 05:49 AM
Granite tile grout line on cut edge Marge Tile Forum/Advice Board 23 12-13-2005 08:00 PM
