Old 07-27-2009, 02:06 PM   #1
joleger
Heat Mat and Ditra...what type of thinset?
Hey Guys,
I read a bunch of the other "heat mat and ditra" threads but I havn't found an answer to my question. Maybe I didn't look hard enough....if so I apologize.
Schluter recommends modified thin set, heat mat, un-mod thin set, ditra.
My question is.....my mat is only 36"x60" and it is going down in a space that is only 50"x68".....do I really need the two types of thin sets? It will be a major PITA to mix two types for such a small space. Plus my ditra will be part on the bare floor and part on the mat.
Please tell me that the modded thin set will be fine.
Thanks for your advice
Cheers
J.O.
joleger is offline   Reply With Quote
Old 07-27-2009, 02:25 PM   #2
flipr
First question will be....
what kind of subfloor/substrate are you installing on?
Phil
flipr is offline   Reply With Quote
Old 07-27-2009, 02:33 PM   #3
joleger
wood floor. 3/4" OSB over eng. trusses 16" on center....and another 1/4" plywood on top of that...glued and screwed.
Not sure if it matters but I am using a NuHeat mat
Old 07-27-2009, 02:33 PM   #4
Hi J.O. Welcome aboard.
It's not what they recommend; it's what they specify.
Even so, I'd use the modified everywhere on the floor when installing the heat mat. Then switch to unmodified.
Or use VersaBond throughout. I've tested it through the years, and I know it sets up.
Old 07-27-2009, 02:36 PM   #5
joleger
Versabond is the modded thinset that I have so I think I will go with that everywhere to avoid switching thinsets half way through the job.
Kerdi/Ditra and heat mat mcfish Tile Forum/Advice Board 6 03-20-2008 09:39 AM
heat mat with ditra - thinset application ccimino Tile Forum/Advice Board 3 03-01-2008 09:01 AM
Ditra and heat mat paulandkody Tile Forum/Advice Board 13 02-29-2008 11:17 PM
Heat mat, latex, Ditra, etc TOOL Tile Forum/Advice Board 0 10-03-2007 08:02 PM
Gypsum-Heat Mat-Ditra-Marble HOW? jacobkoski Professionals' Hangout 17 12-16-2006 11:46 AM
