Unread 08-31-2014, 10:42 AM   #1
J Keeton
need advice on how to build shower pan on slab
Hello,
I’m renovating my bathroom and need some advice on how to build the shower pan. I plan on pulling out the sheetrock and replacing it with durock to the ceiling. The top of the drain is 4 inches higher than the bathroom floor will be with new tile. My main question is how to build the shower pan and curb? I’m also putting a bench in the shower to the left, does that happen before or after I install the pan?
Any advice on how to do this would be great. I’ve done lots of tile work before just never built a shower pan.
Amy
J Keeton is offline   Reply With Quote
Unread 08-31-2014, 11:02 AM   #2
Welcome, Amy.
You sure about that part?
First stop should be a visit to the Shower Construction thread in our Liberry to see how a traditional shower pan is made. The basics are the same with a concrete floor, only the pre-slope differs a bit.
Several options on your installation once that first question above is clarified.
Unread 08-31-2014, 12:38 PM   #3
Choose your waterproofing method first before you do or buy anything. The steps are quite different for a traditionally built shower with a PVC liner and CBU walls vs. a surface-applied membrane. Sometimes the two are mixed a little, but the method you choose will affect your planning and purchase of materials.
Unread 08-31-2014, 01:01 PM   #4
Are you wanting a curbless shower?
Shower pan on concrete slab? Questions and advice request. Kaminari Tile Forum/Advice Board 100 09-04-2012 03:08 PM
Basement Shower Pan build questions hoss1955 Tile Forum/Advice Board 2 05-03-2012 07:11 AM
Anyone ever build a shower pan/tub? California Tile Forum/Advice Board 13 08-18-2011 07:28 AM
how to build a tiled shower pan? Harry G Tile Forum/Advice Board 3 04-20-2004 07:32 AM
need to build a custom shower pan simivalley Tile Forum/Advice Board 3 10-29-2002 05:21 PM
