Unread 11-30-2013, 05:23 PM   #1
Kbike
1/4 inch out
I have a window in a shower I want to use a marble window sill. But it is off approximately 1/4 inch out of level what should I use to make up the 1/4 inch? It has hardie backer on it now. I was thinking a few thin coats of thinset with 24 hrs between. I am as newbie as newbie can be this will be my first time setting marble.
Kevan
Kbike is offline   Reply With Quote
Unread 11-30-2013, 05:31 PM   #2
Welcome, Kevan.
You don't want a window sill in a wet area to be level, you want it to slope to drain by at least 1/4" per horizontal foot and, even more importantly, you want the waterproofing layer to slope that much, also.
What waterproofing method are you using for your shower?
Thinset mortar is not an appropriate product to use for leveling or flattening the substrate, although it is regularly used.
Without knowing just what you need to do, it's difficult to advise further. A photo of what you're working on would help.
Unread 11-30-2013, 05:51 PM   #3
Kbike
The sill has pitch to shower tub area. The owner before me put a glass block window in and the old sill is to the left 1/4 low with a level it has hardie backer and like a red guard over the hardie backer. And that siliconed to the glass block.
Kevan
Unread 11-30-2013, 06:36 PM   #4
I'd use some white thinset to level it out, let it dry overnight, and use the same thinset to set the marble sill. If it wasn't already waterproofed and tile-ready, I might have another suggestion, but at this point I think thinset would be best.
Is the window crooked as well, or just the frame?
Unread 11-30-2013, 06:48 PM   #5
Kbike
Just the frame
Kevan
60-inch tub in 70-inch alcove Gil Smith Tile Forum/Advice Board 9 04-05-2012 10:55 PM
24 inch centers Wynter Tile Forum/Advice Board 14 10-07-2010 08:26 AM
Should I use 0.25 or 0.42 inch hardiboard rrando Tile Forum/Advice Board 6 06-07-2009 09:00 AM
18 inch tiles DAVE_AZ Tile Forum/Advice Board 6 07-18-2004 11:46 AM
Is 23 inch tile too big ? How about 16 inch? Sparky Tile Forum/Advice Board 14 11-06-2002 04:15 PM
